itaps-parallel Tutorial slides
Devine, Karen D kddevin at sandia.gov
Fri Nov 14 11:22:42 CST 2008
OK; I will make this change in the 1_Hello tutorial and in the slides.
I claim right-to-modify the slides for the next few minutes; I¹ll let you
know when it is your turn.
Karen
On 11/14/08 9:51 AM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
> One other change I think would be very useful would be to use a make
> variable IMESH_DIR instead of conditional blocks which depend on
> implementation.  That makes the makefile completely generic; the
> IMESH_DIR can be specified on the make line, e.g.
> make IMESH_DIR=/usr/local/itaps/FMDB
> or can be set as an env variable.
> - tim
> Devine, Karen D wrote:
>> I am going to update the tutorial slides to reflect the iMesh-Defs.inc
>> changes to the Makefiles.  So that we can avoid any conflicts, I will do the
>> update now and let you know when I have committed my changes.
>> Karen
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>           phone: (608) 263-8485      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
