itaps-parallel Tutorial slides
Vitus Leung
vjleung at sandia.gov
Fri Nov 14 11:37:28 CST 2008
I made the change in 2_Load_Balance. I had to rename the variable I was
using.
Vitus
On Fri, 2008-11-14 at 10:22 -0700, Devine, Karen D wrote:
> OK; I will make this change in the 1_Hello tutorial and in the slides.
> I claim right-to-modify the slides for the next few minutes; I¹ll let you
> know when it is your turn.
> Karen
> On 11/14/08 9:51 AM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
> > One other change I think would be very useful would be to use a make
> > variable IMESH_DIR instead of conditional blocks which depend on
> > implementation. That makes the makefile completely generic; the
> > IMESH_DIR can be specified on the make line, e.g.
> > make IMESH_DIR=/usr/local/itaps/FMDB
> > or can be set as an env variable.
> > - tim
> >> I am going to update the tutorial slides to reflect the iMesh-Defs.inc
> >> changes to the Makefiles. So that we can avoid any conflicts, I will do the
> >> update now and let you know when I have committed my changes.
> >> Karen
> > "You will keep in perfect peace him whose mind is
> > steadfast, because he trusts in you." Isaiah 26:3
> > Tim Tautges Argonne National Laboratory
> > (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> > phone: (608) 263-8485 1500 Engineering Dr.
> > fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
