itaps-parallel Name mangling in MOAB
Onkar Sahni osahni at scorec.rpi.edu
Thu Nov 13 14:12:14 CST 2008
After struggling for some time I found one solution in mesh-adaptivity
example, by setting CXX:
CXX=mpicxx
It seems to have worked for now (build and run went trhough fine).
I tried iZoltan and looks like Vitus is already using mpicxx and so it
went through... nice setup Vitus.
I do not know what other problems are lying beneath the surface or might
show up later.
- Onkar
> Hi Onkar,
> Yes, I think it does. And, beware of any purists who might try to argue
> that 4.2/4.3 'should be' compatible. There is simply too much complexity
> here to risk that something, somewhere turns out to NOT be compatible.
> Hence, I suggested leaving the defaults alone and requiring '-4.3' to be
> appended to compiler names if someone actually needs that.
> Mark
> On Thu, 2008-11-13 at 11:57, Onkar Sahni wrote:
>> A small typo in previous message: "Does this mean all
>> libs./services/implementations (which will be FMDB and iZoltan in case
>> of
>> mesh-adaptivity example)...."
>> - Onkar
>> > Does this mean all libs./services/implementations (which will be FMDB
>> and
>> > iZoltan) have to be compiled with gcc 4.3 (if default is 4.3 and thats
>> > what people would use in tutorial)?
>> > It looks like as when I tried to compile using default gcc (which is
>> now
>> > updated to 4.3) then got some errors from mpi.h, see below:
>> > /usr/local/include/mpicxx.h:46:4: error: #error 'Please use the same
>> > version of GCC for compiling MPICH2 and user MPI programs'
>> > Now I don't think I can skip MPICXX using -DMPICH_SKIP_MPICXX as
>> iZoltan
>> > has "using namespace MPI;"
>> > Furthermore, as per my understanding gcc 4.3 needs explicit include
>> for
>> > some headers, for example:
>> > free() - stdlib.h
>> > printf() - stdio.h
>> > strlen() - string.h
>> > In summary, I am hardcoding CXX=g++-4.2 in
>> > 5_Mesh_Refinement/src/iMeshMA/Makefile_mesh_SC08 and do not know if
>> this
>> > will work when libs./services/implementation update their build (with
>> gcc
>> > 4.3).
>> > In general, I would actually prefer to freeze things as of now in
>> terms of
>> > builds, compilers and directory structures etc.
>> > - Onkar
>> >> Hi all,
>> >>    On the mesh machine, I've changed the symbolic links gcc, g++, and
>> >> gfortran in /usr/bin to point to the 4.3 series gnu compilers.  If
>> you'd
>> >> prefer to use the 4.2 series, just use gcc-4.2, etc.
>> >> Ting, this should work for you now.
>> >> - tim
>> >> txie at scorec.rpi.edu wrote:
>> >>> Hi Tim,
>> >>> Thanks. But this file seems too long for me to understand in a short
>> >>> time.
>> >>> May you create a link to gfortran in /usr/bin/, just as gcc and g++?
>> >>> Thanks.
>> >>> Ting
>> >>>> In MOAB, we use an m4 macro to attempt to find compilers
>> >>>> automatically;
>> >>> see ~tautges/ITAPS/SVN/Examples/m4/compiler.m4 on the mesh machine.
>> >>> This
>> >>> produces the F77 or FC variables, which can be over-ridden on the
>> >>> configure line.
>> >>>> - tim
>> >>>>> Tim,
>> >>>>> I add one option FC=/usr/local/gcc-4.3/bin/gfortran in the
>> configure,
>> >>>>> and
>> >>>>> it works now.
>> >>>>> But may you tell me how to fix this minor problem, not by setting
>> >>> option
>> >>>>> in the configure? Since other people may have the same problem in
>> the
>> >>> tutorial, and then they will get undefined errors in compiling FMDB.
>> >>> Thanks.
>> >>>>> Regards,
>> >>>>> Ting
>> >>>>>> Tim,
>> >>>>>> Thanks for your reply. We can test them later.
>> >>>>>> I got another problem when I configured FMDB on mesh machine. It
>> can
>> >>>>>> not
>> >>>>>> find Fortran compiler on mesh machine, and the IMESH_FCDefs.h
>> file
>> >>>>>> is
>> >>> empty.  here is the output from the configure. Did I miss anything
>> in
>> >>> configure file? I did not meet such problem on our SCOREC machine.
>> >>> Thanks.
>> >>>>>> appending configuration tag "F77" to libtool
>> >>>>>> checking for gfortran... no
>> >>>>>> checking for g95... no
>> >>>>>> checking for xlf95... no
>> >>>>>> checking for f95... no
>> >>>>>> checking for fort... no
>> >>>>>> checking for ifort... no
>> >>>>>> checking for ifc... no
>> >>>>>> checking for efc... no
>> >>>>>> checking for pgf95... no
>> >>>>>> checking for lf95... no
>> >>>>>> checking for ftn... no
>> >>>>>> checking for xlf90... no
>> >>>>>> checking for f90... no
>> >>>>>> checking for pgf90... no
>> >>>>>> checking for pghpf... no
>> >>>>>> checking for epcf90... no
>> >>>>>> checking for g77... no
>> >>>>>> checking for xlf... no
>> >>>>>> checking for f77... no
>> >>>>>> checking for frt... no
>> >>>>>> checking for pgf77... no
>> >>>>>> checking for cf77... no
>> >>>>>> checking for fort77... no
>> >>>>>> checking for fl32... no
>> >>>>>> checking for af77... no
>> >>>>>> checking whether we are using the GNU Fortran compiler... no
>> >>>>>> Ting
>> >>>>>>> Good question.  I think the best way to test this would be to
>> >>> configure/build both FMDB and MOAB and use 'nm' to check function
>> >>> signatures in libiMesh.a.  Even better would be to do that with
>> >>> different compilers that mangle names differently, and make sure the
>> >>> two
>> >>>>>>> still agree, but that probably is too much work for now.
>> >>>>>>> - tim
>> >>>>>>>> Tim,
>> >>>>>>>> Thanks for your explanations. They are very clear. I have
>> modified
>> >>>>>>>> FMDB
>> >>>>>>>> like that. But I do not know how to test and use this, and also
>> >>>>>>>> the
>> >>> iMesh-Defs.inc file. May you let me know how to test them if you
>> >>> have
>> >>>>>>>> time? Thanks.
>> >>>>>>>> Regards,
>> >>>>>>>> Ting
>> >>>>>>>>> You bet.  If you have any trouble, just send me or Jason
>> email. -
>> >>>>>>>>> tim
>> >>>>>>>>>> Tim,
>> >>>>>>>>>> Thanks a lot.
>> >>>>>>>>>> Ting
>> >>>>>>>>>>> Hi all,
>> >>>>>>>>>>>    See
>> >>>>>>>>>>> http://
>> trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/configure.in,
>> >>> lines 31-33.  If the script finds a fortran compiler, it runs
>> >>> that
>> >>>>>>>>>>> macro.  That generates definitions for FC_FUNC and FC_FUNC_.
>> >>>>>>>>>>> Then,
>> >>>>>>>>>>> at
>> >>>>>>>>>>> line 869 in configure.in, AC_CONFIG_HEADERS is called to
>> >>>>>>>>>>> produce
>> >>> MBCN_FCDefs.h, which contains substituted definitions for FC_FUNC
>> >>> and
>> >>>>>>>>>>> FC_FUNC_.  Those macros are used in iMesh_protos.h
>> >>>>>>>>>>> (http://
>> trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/tools/iMesh/iMesh_protos.h)
>> >>> to mangle the imesh function names.
>> >>>>>>>>>>> If you're doing this in FMDB, it's probably easier to
>> eliminate
>> >>> going
>> >>>>>>>>>>> through MBCN_FCDefs.h or equivalent and call
>> AC_CONFIG_HEADERS
>> >>> directly
>> >>>>>>>>>>> on iMesh.h, though you'll have to make a iMesh.h.in file for
>> >>>>>>>>>>> that to
>> >>>>>>>>>>> work properly.
>> >>>>>>>>>>> Any questions, let me know.
>> >>>>>>>>>>> - tim
>> >>> "You will keep in perfect peace him whose mind is
>> >>>>>>>>>>>    steadfast, because he trusts in you."
>> Isaiah
>> >>> 26:3
>> >>>>>>>>>>>               Tim Tautges            Argonne National
>> >>>>>>>>>>> Laboratory
>> >>>>>>>>>>>           (tautges at mcs.anl.gov)      (telecommuting from
>> >>>>>>>>>>> UW-Madison)
>> >>>>>>>>>>>           phone: (608) 263-8485      1500 Engineering Dr.
>> >>>>>>>>>>>             fax: (608) 263-4499      Madison, WI 53706
>> >>>>>>>>>    steadfast, because he trusts in you."               Isaiah
>> >>>>>>>>> 26:3
>> Laboratory
>> >>> UW-Madison)
>> >>>>>>> "You
>> 26:3
>> >>>>>>>               Tim Tautges            Argonne National Laboratory
>> >>>>>>> UW-Madison)
>> "You
>> >>>>    steadfast, because he trusts in you."               Isaiah 26:3
>> UW-Madison)
>> >>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> Mark C. Miller, Lawrence Livermore National Laboratory
> email: mailto:miller86 at llnl.gov
> (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
> (Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
