itaps-parallel Name mangling in MOAB
Tim Tautges tautges at mcs.anl.gov
Thu Nov 13 14:41:19 CST 2008
Sorry for the confusion gang.  To review:
- if you want to compile fortran apps on imesh, and you're using
gfortran, it'll have to be gfortran 4.3, since they didn't support %VAL
correctly until then
- mpich appears to require the same version of the compiler as was used
to compile mpi (not sure why)
- in my experience, gcc4.2 and 4.3 are compatible.
- tim
Mark Miller wrote:
> Hi Onkar,
> Yes, I think it does. And, beware of any purists who might try to argue
> that 4.2/4.3 'should be' compatible. There is simply too much complexity
> here to risk that something, somewhere turns out to NOT be compatible.
> Hence, I suggested leaving the defaults alone and requiring '-4.3' to be
> appended to compiler names if someone actually needs that.
> Mark
> On Thu, 2008-11-13 at 11:57, Onkar Sahni wrote:
>> A small typo in previous message: "Does this mean all
>> libs./services/implementations (which will be FMDB and iZoltan in case of
>> mesh-adaptivity example)...."
>> - Onkar
>>> Does this mean all libs./services/implementations (which will be FMDB and
>>> iZoltan) have to be compiled with gcc 4.3 (if default is 4.3 and thats
>>> what people would use in tutorial)?
>>> It looks like as when I tried to compile using default gcc (which is now
>>> updated to 4.3) then got some errors from mpi.h, see below:
>>> /usr/local/include/mpicxx.h:46:4: error: #error 'Please use the same
>>> version of GCC for compiling MPICH2 and user MPI programs'
>>> Now I don't think I can skip MPICXX using -DMPICH_SKIP_MPICXX as iZoltan
>>> has "using namespace MPI;"
>>> Furthermore, as per my understanding gcc 4.3 needs explicit include for
>>> some headers, for example:
>>> free() - stdlib.h
>>> printf() - stdio.h
>>> strlen() - string.h
>>> In summary, I am hardcoding CXX=g++-4.2 in
>>> 5_Mesh_Refinement/src/iMeshMA/Makefile_mesh_SC08 and do not know if this
>>> will work when libs./services/implementation update their build (with gcc
>>> 4.3).
>>> In general, I would actually prefer to freeze things as of now in terms of
>>> builds, compilers and directory structures etc.
>>> - Onkar
>>>> Hi all,
>>>>    On the mesh machine, I've changed the symbolic links gcc, g++, and
>>>> gfortran in /usr/bin to point to the 4.3 series gnu compilers.  If you'd
>>>> prefer to use the 4.2 series, just use gcc-4.2, etc.
>>>> Ting, this should work for you now.
>>>> - tim
>>>> txie at scorec.rpi.edu wrote:
>>>>> Hi Tim,
>>>>> Thanks. But this file seems too long for me to understand in a short
>>>>> time.
>>>>> May you create a link to gfortran in /usr/bin/, just as gcc and g++?
>>>>> Thanks.
>>>>> Ting
>>>>>> In MOAB, we use an m4 macro to attempt to find compilers
>>>>>> automatically;
>>>>> see ~tautges/ITAPS/SVN/Examples/m4/compiler.m4 on the mesh machine.
>>>>> This
>>>>> produces the F77 or FC variables, which can be over-ridden on the
>>>>> configure line.
>>>>>> - tim
>>>>>>> Tim,
>>>>>>> I add one option FC=/usr/local/gcc-4.3/bin/gfortran in the configure,
>>>>>>> and
>>>>>>> it works now.
>>>>>>> But may you tell me how to fix this minor problem, not by setting
>>>>> option
>>>>>>> in the configure? Since other people may have the same problem in the
>>>>> tutorial, and then they will get undefined errors in compiling FMDB.
>>>>> Thanks.
>>>>>>> Regards,
>>>>>>> Ting
>>>>>>>> Tim,
>>>>>>>> Thanks for your reply. We can test them later.
>>>>>>>> I got another problem when I configured FMDB on mesh machine. It can
>>>>>>>> not
>>>>>>>> find Fortran compiler on mesh machine, and the IMESH_FCDefs.h file
>>>>>>>> is
>>>>> empty.  here is the output from the configure. Did I miss anything in
>>>>> configure file? I did not meet such problem on our SCOREC machine.
>>>>> Thanks.
>>>>>>>> appending configuration tag "F77" to libtool
>>>>>>>> checking for gfortran... no
>>>>>>>> checking for g95... no
>>>>>>>> checking for xlf95... no
>>>>>>>> checking for f95... no
>>>>>>>> checking for fort... no
>>>>>>>> checking for ifort... no
>>>>>>>> checking for ifc... no
>>>>>>>> checking for efc... no
>>>>>>>> checking for pgf95... no
>>>>>>>> checking for lf95... no
>>>>>>>> checking for ftn... no
>>>>>>>> checking for xlf90... no
>>>>>>>> checking for f90... no
>>>>>>>> checking for pgf90... no
>>>>>>>> checking for pghpf... no
>>>>>>>> checking for epcf90... no
>>>>>>>> checking for g77... no
>>>>>>>> checking for xlf... no
>>>>>>>> checking for f77... no
>>>>>>>> checking for frt... no
>>>>>>>> checking for pgf77... no
>>>>>>>> checking for cf77... no
>>>>>>>> checking for fort77... no
>>>>>>>> checking for fl32... no
>>>>>>>> checking for af77... no
>>>>>>>> checking whether we are using the GNU Fortran compiler... no
>>>>>>>> Ting
>>>>>>>>> Good question.  I think the best way to test this would be to
>>>>> configure/build both FMDB and MOAB and use 'nm' to check function
>>>>> signatures in libiMesh.a.  Even better would be to do that with
>>>>> different compilers that mangle names differently, and make sure the
>>>>> two
>>>>>>>>> still agree, but that probably is too much work for now.
>>>>>>>>> - tim
>>>>>>>>>> Tim,
>>>>>>>>>> Thanks for your explanations. They are very clear. I have modified
>>>>>>>>>> FMDB
>>>>>>>>>> like that. But I do not know how to test and use this, and also
>>>>>>>>>> the
>>>>> iMesh-Defs.inc file. May you let me know how to test them if you
>>>>> have
>>>>>>>>>> time? Thanks.
>>>>>>>>>> Regards,
>>>>>>>>>> Ting
>>>>>>>>>>> You bet.  If you have any trouble, just send me or Jason email. -
>>>>>>>>>>> tim
>>>>>>>>>>>> Tim,
>>>>>>>>>>>> Thanks a lot.
>>>>>>>>>>>> Ting
>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>>    See
>>>>>>>>>>>>> http:// trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/configure.in,
>>>>> lines 31-33.  If the script finds a fortran compiler, it runs
>>>>> that
>>>>>>>>>>>>> macro.  That generates definitions for FC_FUNC and FC_FUNC_.
>>>>>>>>>>>>> Then,
>>>>>>>>>>>>> at
>>>>>>>>>>>>> line 869 in configure.in, AC_CONFIG_HEADERS is called to
>>>>>>>>>>>>> produce
>>>>> MBCN_FCDefs.h, which contains substituted definitions for FC_FUNC
>>>>> and
>>>>>>>>>>>>> FC_FUNC_.  Those macros are used in iMesh_protos.h
>>>>>>>>>>>>> (http:// trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/tools/iMesh/iMesh_protos.h)
>>>>> to mangle the imesh function names.
>>>>>>>>>>>>> If you're doing this in FMDB, it's probably easier to eliminate
>>>>> going
>>>>>>>>>>>>> through MBCN_FCDefs.h or equivalent and call AC_CONFIG_HEADERS
>>>>> directly
>>>>>>>>>>>>> on iMesh.h, though you'll have to make a iMesh.h.in file for
>>>>>>>>>>>>> that to
>>>>>>>>>>>>> work properly.
>>>>>>>>>>>>> Any questions, let me know.
>>>>>>>>>>>>> - tim
>>>>> "You will keep in perfect peace him whose mind is
>>>>>>>>>>>>>    steadfast, because he trusts in you."               Isaiah
>>>>> 26:3
>>>>>>>>>>>>>               Tim Tautges            Argonne National
>>>>>>>>>>>>> Laboratory
>>>>>>>>>>>>>           (tautges at mcs.anl.gov)      (telecommuting from
>>>>>>>>>>>>> UW-Madison)
>>>>>>>>>>>>>           phone: (608) 263-8485      1500 Engineering Dr.
>>>>>>>>>>>>>             fax: (608) 263-4499      Madison, WI 53706
>>>>>>>>>>> 26:3
>>>>>>>>>>>               Tim Tautges            Argonne National Laboratory
>>>>> UW-Madison)
>>>>>>>>> "You
>>>>>>>>>    steadfast, because he trusts in you."               Isaiah 26:3
>>>>>>>>> UW-Madison)
>>>>>> ================================================================ "You
>>>>>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
More information about the itaps-parallel mailing list
