itaps-parallel Name mangling in MOAB
Mark Miller miller86 at llnl.gov
Thu Nov 13 13:58:40 CST 2008
Hi Onkar,
Yes, I think it does. And, beware of any purists who might try to argue
that 4.2/4.3 'should be' compatible. There is simply too much complexity
here to risk that something, somewhere turns out to NOT be compatible.
Hence, I suggested leaving the defaults alone and requiring '-4.3' to be
appended to compiler names if someone actually needs that.
On Thu, 2008-11-13 at 11:57, Onkar Sahni wrote:
> A small typo in previous message: "Does this mean all
> libs./services/implementations (which will be FMDB and iZoltan in case of
> mesh-adaptivity example)...."
> - Onkar
> > Does this mean all libs./services/implementations (which will be FMDB and
> > iZoltan) have to be compiled with gcc 4.3 (if default is 4.3 and thats
> > what people would use in tutorial)?
> > It looks like as when I tried to compile using default gcc (which is now
> > updated to 4.3) then got some errors from mpi.h, see below:
> > /usr/local/include/mpicxx.h:46:4: error: #error 'Please use the same
> > version of GCC for compiling MPICH2 and user MPI programs'
> > Now I don't think I can skip MPICXX using -DMPICH_SKIP_MPICXX as iZoltan
> > has "using namespace MPI;"
> > Furthermore, as per my understanding gcc 4.3 needs explicit include for
> > some headers, for example:
> > free() - stdlib.h
> > printf() - stdio.h
> > strlen() - string.h
> > In summary, I am hardcoding CXX=g++-4.2 in
> > 5_Mesh_Refinement/src/iMeshMA/Makefile_mesh_SC08 and do not know if this
> > will work when libs./services/implementation update their build (with gcc
> > 4.3).
> > In general, I would actually prefer to freeze things as of now in terms of
> > builds, compilers and directory structures etc.
> > - Onkar
> >> Hi all,
> >>    On the mesh machine, I've changed the symbolic links gcc, g++, and
> >> gfortran in /usr/bin to point to the 4.3 series gnu compilers.  If you'd
> >> prefer to use the 4.2 series, just use gcc-4.2, etc.
> >> Ting, this should work for you now.
> >> - tim
> >> txie at scorec.rpi.edu wrote:
> >>> Hi Tim,
> >>> Thanks. But this file seems too long for me to understand in a short
> >>> time.
> >>> May you create a link to gfortran in /usr/bin/, just as gcc and g++?
> >>> Thanks.
> >>> Ting
> >>>> In MOAB, we use an m4 macro to attempt to find compilers
> >>>> automatically;
> >>> see ~tautges/ITAPS/SVN/Examples/m4/compiler.m4 on the mesh machine.
> >>> This
> >>> produces the F77 or FC variables, which can be over-ridden on the
> >>> configure line.
> >>>> - tim
> >>>>> Tim,
> >>>>> I add one option FC=/usr/local/gcc-4.3/bin/gfortran in the configure,
> >>>>> and
> >>>>> it works now.
> >>>>> But may you tell me how to fix this minor problem, not by setting
> >>> option
> >>>>> in the configure? Since other people may have the same problem in the
> >>> tutorial, and then they will get undefined errors in compiling FMDB.
> >>> Thanks.
> >>>>> Regards,
> >>>>> Ting
> >>>>>> Tim,
> >>>>>> Thanks for your reply. We can test them later.
> >>>>>> I got another problem when I configured FMDB on mesh machine. It can
> >>>>>> not
> >>>>>> find Fortran compiler on mesh machine, and the IMESH_FCDefs.h file
> >>>>>> is
> >>> empty.  here is the output from the configure. Did I miss anything in
> >>> configure file? I did not meet such problem on our SCOREC machine.
> >>> Thanks.
> >>>>>> appending configuration tag "F77" to libtool
> >>>>>> checking for gfortran... no
> >>>>>> checking for g95... no
> >>>>>> checking for xlf95... no
> >>>>>> checking for f95... no
> >>>>>> checking for fort... no
> >>>>>> checking for ifort... no
> >>>>>> checking for ifc... no
> >>>>>> checking for efc... no
> >>>>>> checking for pgf95... no
> >>>>>> checking for lf95... no
> >>>>>> checking for ftn... no
> >>>>>> checking for xlf90... no
> >>>>>> checking for f90... no
> >>>>>> checking for pgf90... no
> >>>>>> checking for pghpf... no
> >>>>>> checking for epcf90... no
> >>>>>> checking for g77... no
> >>>>>> checking for xlf... no
> >>>>>> checking for f77... no
> >>>>>> checking for frt... no
> >>>>>> checking for pgf77... no
> >>>>>> checking for cf77... no
> >>>>>> checking for fort77... no
> >>>>>> checking for fl32... no
> >>>>>> checking for af77... no
> >>>>>> checking whether we are using the GNU Fortran compiler... no
> >>>>>> Ting
> >>>>>>> Good question.  I think the best way to test this would be to
> >>> configure/build both FMDB and MOAB and use 'nm' to check function
> >>> signatures in libiMesh.a.  Even better would be to do that with
> >>> different compilers that mangle names differently, and make sure the
> >>> two
> >>>>>>> still agree, but that probably is too much work for now.
> >>>>>>> - tim
> >>>>>>>> Tim,
> >>>>>>>> Thanks for your explanations. They are very clear. I have modified
> >>>>>>>> FMDB
> >>>>>>>> like that. But I do not know how to test and use this, and also
> >>>>>>>> the
> >>> iMesh-Defs.inc file. May you let me know how to test them if you
> >>> have
> >>>>>>>> time? Thanks.
> >>>>>>>> Regards,
> >>>>>>>> Ting
> >>>>>>>>> You bet.  If you have any trouble, just send me or Jason email. -
> >>>>>>>>> tim
> >>>>>>>>>> Tim,
> >>>>>>>>>> Thanks a lot.
> >>>>>>>>>> Ting
> >>>>>>>>>>> Hi all,
> >>>>>>>>>>>    See
> >>>>>>>>>>> http:// trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/configure.in,
> >>> lines 31-33.  If the script finds a fortran compiler, it runs
> >>> that
> >>>>>>>>>>> macro.  That generates definitions for FC_FUNC and FC_FUNC_.
> >>>>>>>>>>> Then,
> >>>>>>>>>>> at
> >>>>>>>>>>> line 869 in configure.in, AC_CONFIG_HEADERS is called to
> >>>>>>>>>>> produce
> >>> MBCN_FCDefs.h, which contains substituted definitions for FC_FUNC
> >>> and
> >>>>>>>>>>> FC_FUNC_.  Those macros are used in iMesh_protos.h
> >>>>>>>>>>> (http:// trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/tools/iMesh/iMesh_protos.h)
> >>> to mangle the imesh function names.
> >>>>>>>>>>> If you're doing this in FMDB, it's probably easier to eliminate
> >>> going
> >>>>>>>>>>> through MBCN_FCDefs.h or equivalent and call AC_CONFIG_HEADERS
> >>> directly
> >>>>>>>>>>> on iMesh.h, though you'll have to make a iMesh.h.in file for
> >>>>>>>>>>> that to
> >>>>>>>>>>> work properly.
> >>>>>>>>>>> Any questions, let me know.
> >>>>>>>>>>> - tim
> >>> "You will keep in perfect peace him whose mind is
> >>>>>>>>>>>    steadfast, because he trusts in you."               Isaiah
> >>> 26:3
> >>>>>>>>>>>               Tim Tautges            Argonne National
> >>>>>>>>>>> Laboratory
> >>>>>>>>>>>           (tautges at mcs.anl.gov)      (telecommuting from
> >>>>>>>>>>> UW-Madison)
> >>>>>>>>>>>           phone: (608) 263-8485      1500 Engineering Dr.
> >>>>>>>>>>>             fax: (608) 263-4499      Madison, WI 53706
> >>>>>>>>> 26:3
> >>>>>>>>>               Tim Tautges            Argonne National Laboratory
> >>> UW-Madison)
> >>>>>>> "You
> >>>>>>>    steadfast, because he trusts in you."               Isaiah 26:3
> >>>>>>> UW-Madison)
> >>>> ================================================================ "You
> >>>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
