itaps-parallel Name mangling in MOAB
Onkar Sahni osahni at scorec.rpi.edu
Thu Nov 13 13:57:27 CST 2008
A small typo in previous message: "Does this mean all
libs./services/implementations (which will be FMDB and iZoltan in case of
mesh-adaptivity example)...."
- Onkar
> Does this mean all libs./services/implementations (which will be FMDB and
> iZoltan) have to be compiled with gcc 4.3 (if default is 4.3 and thats
> what people would use in tutorial)?
> It looks like as when I tried to compile using default gcc (which is now
> updated to 4.3) then got some errors from mpi.h, see below:
> /usr/local/include/mpicxx.h:46:4: error: #error 'Please use the same
> version of GCC for compiling MPICH2 and user MPI programs'
> Now I don't think I can skip MPICXX using -DMPICH_SKIP_MPICXX as iZoltan
> has "using namespace MPI;"
> Furthermore, as per my understanding gcc 4.3 needs explicit include for
> some headers, for example:
> free() - stdlib.h
> printf() - stdio.h
> strlen() - string.h
> In summary, I am hardcoding CXX=g++-4.2 in
> 5_Mesh_Refinement/src/iMeshMA/Makefile_mesh_SC08 and do not know if this
> will work when libs./services/implementation update their build (with gcc
> 4.3).
> In general, I would actually prefer to freeze things as of now in terms of
> builds, compilers and directory structures etc.
> - Onkar
>> Hi all,
>>    On the mesh machine, I've changed the symbolic links gcc, g++, and
>> gfortran in /usr/bin to point to the 4.3 series gnu compilers.  If you'd
>> prefer to use the 4.2 series, just use gcc-4.2, etc.
>> Ting, this should work for you now.
>> - tim
>> txie at scorec.rpi.edu wrote:
>>> Hi Tim,
>>> Thanks. But this file seems too long for me to understand in a short
>>> time.
>>> May you create a link to gfortran in /usr/bin/, just as gcc and g++?
>>> Thanks.
>>> Ting
>>>> In MOAB, we use an m4 macro to attempt to find compilers
>>>> automatically;
>>> see ~tautges/ITAPS/SVN/Examples/m4/compiler.m4 on the mesh machine.
>>> This
>>> produces the F77 or FC variables, which can be over-ridden on the
>>> configure line.
>>>> - tim
>>>>> Tim,
>>>>> I add one option FC=/usr/local/gcc-4.3/bin/gfortran in the configure,
>>>>> and
>>>>> it works now.
>>>>> But may you tell me how to fix this minor problem, not by setting
>>> option
>>>>> in the configure? Since other people may have the same problem in the
>>> tutorial, and then they will get undefined errors in compiling FMDB.
>>> Thanks.
>>>>> Regards,
>>>>> Ting
>>>>>> Tim,
>>>>>> Thanks for your reply. We can test them later.
>>>>>> I got another problem when I configured FMDB on mesh machine. It can
>>>>>> not
>>>>>> find Fortran compiler on mesh machine, and the IMESH_FCDefs.h file
>>>>>> is
>>> empty.  here is the output from the configure. Did I miss anything in
>>> configure file? I did not meet such problem on our SCOREC machine.
>>> Thanks.
>>>>>> appending configuration tag "F77" to libtool
>>>>>> checking for gfortran... no
>>>>>> checking for g95... no
>>>>>> checking for xlf95... no
>>>>>> checking for f95... no
>>>>>> checking for fort... no
>>>>>> checking for ifort... no
>>>>>> checking for ifc... no
>>>>>> checking for efc... no
>>>>>> checking for pgf95... no
>>>>>> checking for lf95... no
>>>>>> checking for ftn... no
>>>>>> checking for xlf90... no
>>>>>> checking for f90... no
>>>>>> checking for pgf90... no
>>>>>> checking for pghpf... no
>>>>>> checking for epcf90... no
>>>>>> checking for g77... no
>>>>>> checking for xlf... no
>>>>>> checking for f77... no
>>>>>> checking for frt... no
>>>>>> checking for pgf77... no
>>>>>> checking for cf77... no
>>>>>> checking for fort77... no
>>>>>> checking for fl32... no
>>>>>> checking for af77... no
>>>>>> checking whether we are using the GNU Fortran compiler... no
>>>>>> Ting
>>>>>>> Good question.  I think the best way to test this would be to
>>> configure/build both FMDB and MOAB and use 'nm' to check function
>>> signatures in libiMesh.a.  Even better would be to do that with
>>> different compilers that mangle names differently, and make sure the
>>> two
>>>>>>> still agree, but that probably is too much work for now.
>>>>>>> - tim
>>>>>>>> Tim,
>>>>>>>> Thanks for your explanations. They are very clear. I have modified
>>>>>>>> FMDB
>>>>>>>> like that. But I do not know how to test and use this, and also
>>>>>>>> the
>>> iMesh-Defs.inc file. May you let me know how to test them if you
>>> have
>>>>>>>> time? Thanks.
>>>>>>>> Regards,
>>>>>>>> Ting
>>>>>>>>> You bet.  If you have any trouble, just send me or Jason email. -
>>>>>>>>> tim
>>>>>>>>>> Tim,
>>>>>>>>>> Thanks a lot.
>>>>>>>>>> Ting
>>>>>>>>>>> Hi all,
>>>>>>>>>>>    See
>>>>>>>>>>> http://trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/configure.in,
>>> lines 31-33.  If the script finds a fortran compiler, it runs
>>> that
>>>>>>>>>>> macro.  That generates definitions for FC_FUNC and FC_FUNC_.
>>>>>>>>>>> Then,
>>>>>>>>>>> at
>>>>>>>>>>> line 869 in configure.in, AC_CONFIG_HEADERS is called to
>>>>>>>>>>> produce
>>> MBCN_FCDefs.h, which contains substituted definitions for FC_FUNC
>>> and
>>>>>>>>>>> FC_FUNC_.  Those macros are used in iMesh_protos.h
>>>>>>>>>>> (http://trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/tools/iMesh/iMesh_protos.h)
>>> to mangle the imesh function names.
>>>>>>>>>>> If you're doing this in FMDB, it's probably easier to eliminate
>>> going
>>>>>>>>>>> through MBCN_FCDefs.h or equivalent and call AC_CONFIG_HEADERS
>>> directly
>>>>>>>>>>> on iMesh.h, though you'll have to make a iMesh.h.in file for
>>>>>>>>>>> that to
>>>>>>>>>>> work properly.
>>>>>>>>>>> Any questions, let me know.
>>>>>>>>>>> - tim
>>> "You will keep in perfect peace him whose mind is
>>>>>>>>>>>    steadfast, because he trusts in you."               Isaiah
>>> 26:3
>>>>>>>>>>>               Tim Tautges            Argonne National
>>>>>>>>>>> Laboratory
>>>>>>>>>>>           (tautges at mcs.anl.gov)      (telecommuting from
>>>>>>>>>>> UW-Madison)
>>>>>>>>>>>           phone: (608) 263-8485      1500 Engineering Dr.
>>>>>>>>>>>             fax: (608) 263-4499      Madison, WI 53706
>>>>>>>>> 26:3
>>>>>>>>>               Tim Tautges            Argonne National Laboratory
>>> UW-Madison)
>>>>>>> "You
>>>>>>>    steadfast, because he trusts in you."               Isaiah 26:3
>>>>>>> UW-Madison)
>>>> ================================================================ "You
>>>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
More information about the itaps-parallel mailing list
