itaps-parallel Issues to be resolved from today's telecon
Vitus Leung
vjleung at sandia.gov
Wed Nov 12 17:01:33 CST 2008
Tim,
It looks like you are still the only one who can write to Dist. You
need the change the group for Dist.
Vitus
On Wed, 2008-11-12 at 15:48 -0700, Lori A. Diachin wrote:
> Lori: Set up itaps-announce and itaps-user mailing lists
> Tim: Update slides to reflect any changes to FindConnect and HelloMesh,
> Sets and Tags, etc. Includes removal of 0 for root set. Update source
> code as needed.
> Tim: send out fortran name mangling instructions using configure; others
> analyze and try to implement to have consistency across ITAPS
> implementations and services
> Ryan, Martin, Vitus, Onkar: short introduction in HandsOn_Session.txt
> file in the tutorial examples reflecting what you are going to learn,
> the tools used, etc. See Karen's Hello/HandsOn for an example. All
> changes to HandsOn_Session.txt files should be complete by Thursday COB
> for printing.
> Onkar/Ting: Fix the errors in the iMesh.h second order adjacency
> information based on the email Karen sent on 11/7 for the functions
> iMesh_getEnt2ndAdj, iMesh_getEntArr2ndAdj ... looks like there are a
> couple of parameters that need to be defined and couple that are defined
> that are not in the argument list (see the end of the message).
> Lori: update the web pages to reflect iMeshP interfaces; no tarballs yet
> All: update tarballs and place in the /usr/local/itaps/Dist directory;
> send email to all for testing.
> Error in iMesh.h file
> /**\brief Get "2nd order" adjacencies to an entity
> * Get "2nd order" adjacencies to an entity, that is, from an entity,
> through
> * other entities of a specified "bridge" dimension, to other entities
> of another
> * specified "to" dimension.
> * \param instance iMesh instance for this call
> * \param entity_handle Entity from which adjacencies are requested
> * \param bridge_dimension Bridge dimension for 2nd order adjacencies
> * \param to_dimension Dimension of adjacent entities returned
> * \param adjacent_entities Adjacent entities
> * \param adjacent_entities_allocated Allocated size of returned array
> * \param adjacent_entities_size Occupied size of returned array
> * \param err
> void iMesh_getEnt2ndAdj( iMesh_Instance instance,
> iBase_EntityHandle entity_handle,
> int order_adjacent_key,
> int requested_entity_type,
> iBase_EntityHandle** adjacent_entities,
> int* adjacent_entities_allocated,
> int* adjacent_entities_size,
> int* err );
More information about the itaps-parallel
