itaps-parallel Issues to be resolved from today's telecon
Tim Tautges tautges at mcs.anl.gov
Wed Nov 12 17:38:53 CST 2008
Sorry 'bout that, done now.
- tim
Vitus Leung wrote:
> Tim,
> It looks like you are still the only one who can write to Dist.  You
> need the change the group for Dist.
> Vitus
> On Wed, 2008-11-12 at 15:48 -0700, Lori A. Diachin wrote:
>> Lori:  Set up itaps-announce and itaps-user mailing lists
>> Tim: Update slides to reflect any changes to FindConnect and HelloMesh,
>> Sets and Tags, etc.  Includes removal of 0 for root set.  Update source
>> code as needed.
>> Tim: send out fortran name mangling instructions using configure; others
>> analyze and try to implement to have consistency across ITAPS
>> implementations and services
>> Ryan, Martin, Vitus, Onkar: short introduction in HandsOn_Session.txt
>> file in the tutorial examples reflecting what you are going to learn,
>> the tools used, etc.   See Karen's Hello/HandsOn for an example.  All
>> changes to HandsOn_Session.txt files should be complete by Thursday COB
>> for printing.
>> Onkar/Ting: Fix the errors in the iMesh.h second order adjacency
>> information based on the email Karen sent on 11/7 for the functions
>> iMesh_getEnt2ndAdj, iMesh_getEntArr2ndAdj  ... looks like there are a
>> couple of parameters that need to be defined and couple that are defined
>> that are not in the argument list (see the end of the message).
>> Lori: update the web pages to reflect iMeshP interfaces; no tarballs yet
>> All: update tarballs and place in the /usr/local/itaps/Dist directory;
>> send email to all for testing.
>> Error in iMesh.h file
>>   /**\brief Get "2nd order" adjacencies to an entity
>>  * Get "2nd order" adjacencies to an entity, that is, from an entity,
>> through
>>  * other entities of a specified "bridge" dimension, to other entities
>> of another
>>  * specified "to" dimension.
>>  * \param instance iMesh instance for this call
>>  * \param entity_handle Entity from which adjacencies are requested
>>  * \param bridge_dimension Bridge dimension for 2nd order adjacencies
>>  * \param to_dimension Dimension of adjacent entities returned
>>  * \param adjacent_entities Adjacent entities
>>  * \param adjacent_entities_allocated Allocated size of returned array
>>  * \param adjacent_entities_size Occupied size of returned array
>>  * \param err
>>   void iMesh_getEnt2ndAdj( iMesh_Instance instance,
>>                            iBase_EntityHandle entity_handle,
>>                            int order_adjacent_key,
>>                            int requested_entity_type,
>>                            iBase_EntityHandle** adjacent_entities,
>>                            int* adjacent_entities_allocated,
>>                            int* adjacent_entities_size,
>>                            int* err );
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
