itaps-parallel Issues to be resolved from today's telecon
Lori A. Diachin
diachin2 at llnl.gov
Wed Nov 12 16:48:47 CST 2008
Lori: Set up itaps-announce and itaps-user mailing lists
Tim: Update slides to reflect any changes to FindConnect and HelloMesh,
Sets and Tags, etc. Includes removal of 0 for root set. Update source
code as needed.
Tim: send out fortran name mangling instructions using configure; others
analyze and try to implement to have consistency across ITAPS
implementations and services
Ryan, Martin, Vitus, Onkar: short introduction in HandsOn_Session.txt
file in the tutorial examples reflecting what you are going to learn,
the tools used, etc. See Karen's Hello/HandsOn for an example. All
changes to HandsOn_Session.txt files should be complete by Thursday COB
for printing.
Onkar/Ting: Fix the errors in the iMesh.h second order adjacency
information based on the email Karen sent on 11/7 for the functions
iMesh_getEnt2ndAdj, iMesh_getEntArr2ndAdj ... looks like there are a
couple of parameters that need to be defined and couple that are defined
that are not in the argument list (see the end of the message).
Lori: update the web pages to reflect iMeshP interfaces; no tarballs yet
All: update tarballs and place in the /usr/local/itaps/Dist directory;
send email to all for testing.
Error in iMesh.h file
/**\brief Get "2nd order" adjacencies to an entity
* Get "2nd order" adjacencies to an entity, that is, from an entity,
through
* other entities of a specified "bridge" dimension, to other entities
of another
* specified "to" dimension.
* \param instance iMesh instance for this call
* \param entity_handle Entity from which adjacencies are requested
* \param bridge_dimension Bridge dimension for 2nd order adjacencies
* \param to_dimension Dimension of adjacent entities returned
* \param adjacent_entities Adjacent entities
* \param adjacent_entities_allocated Allocated size of returned array
* \param adjacent_entities_size Occupied size of returned array
* \param err
void iMesh_getEnt2ndAdj( iMesh_Instance instance,
iBase_EntityHandle entity_handle,
int order_adjacent_key,
int requested_entity_type,
iBase_EntityHandle** adjacent_entities,
int* adjacent_entities_allocated,
int* adjacent_entities_size,
int* err );
More information about the itaps-parallel
