itaps-parallel Examples on mesh machine
Tim Tautges tautges at mcs.anl.gov
Wed Nov 12 10:18:50 CST 2008
Hi all,
   I've put the HelloMesh on the mesh machine, in
~tautges/ITAPS/SVN/Examples and below.  You should be able to copy that
whole directory.  See the README for instructions on how to build.
Karen, the example there doesn't have any arrays, so it might not be
sufficient for building your hello imeshp; I'll work on a more advanced
example next.
I haven't tried building with other implementations yet (besides MOAB),
will try that next.  Note, however, this test does depend on having
iMesh-Defs.inc, so if it's not there yet, it won't work.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
