itaps-parallel Going to commit examples...
Tim Tautges tautges at mcs.anl.gov
Wed Nov 12 09:34:26 CST 2008
Hi all,
   I've built the HelloMesh examples in f77, f90, c, and c++.  I'll
commit them to the rpi repo shortly.  Lori, I redid the configure stuff
that you had done, to make it a bit easier.  You can now enable/disable
each language individually, point to your imesh/igeom/etc. install
directory, and off it goes.  I also put all the languages in the same
directory for each test, since I think that's easier to work with.
I'll build these on the mesh machine after committing them.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
