itaps-parallel FronTier tutorial
Ryan Kaufman
rykauf at gmail.com
Sat Nov 8 12:31:06 CST 2008
Thanks. I thought I wrote it... It's in the document now.
On Fri, Nov 7, 2008 at 11:21 PM, <isenburg1 at llnl.gov> wrote:
> hi ryan,
> i tried running your tutorial. there is some issue with libhdf5.so.0
> libraries. are they missing or is an obvious path missing?
> isenburg at mesh:~/FronTier_tutorial$ ./HelloFronTier
> ./HelloFronTier: error while loading shared libraries: libiMesh.so.0: cannot
> open shared object file: No such file or directory
> isenburg at mesh:~/FronTier_tutorial$ echo $LD_LIBRARY_PATH
> /usr/local/itaps/FMDB_iMeshP/lib/
> isenburg at mesh:~/FronTier_tutorial$ export
> LD_LIBRARY_PATH=/usr/local/itaps/MOABser/lib:${LD_LIBRARY_PATH}
> /usr/local/itaps/MOABser/lib:/usr/local/itaps/FMDB_iMeshP/lib/
> ./HelloFronTier: error while loading shared libraries: libhdf5.so.0: cannot
> cheers
> martin
~Ryan Kaufman
More information about the itaps-parallel
