itaps-parallel FronTier tutorial
Mark Miller miller86 at llnl.gov
Sun Nov 9 21:44:24 CST 2008
Hi Ryan and Martin,
Ok, I tried it and got further after finding hdf5 libs...
./HelloFronTier: error while loading shared libraries: libiMesh.so.0: cannot open shared object file: No such file or directory
mcmiller at mesh:~$ env LD_LIBRARY_PATH=/usr/local/itaps/MOABser/lib ./HelloFronTier
./HelloFronTier: error while loading shared libraries: libhdf5.so.0: cannot open shared object file: No such file or directory
mcmiller at mesh:~$ env LD_LIBRARY_PATH=/usr/local/itaps/MOABser/lib:/usr/local/hdf5serial/lib ./HelloFronTier
error type 3 in: iMesh_load
mcmiller at mesh:~$ env LD_LIBRARY_PATH=/usr/local/itaps/MOABser/lib:/usr/local/hdf5serial/lib ./HelloFronTier /usr/local/itaps/FronTier_tutorial/vtk_files/circle.vtk -o vtk
Usage: example -o output
Also, as I am sure you are probably already thinking, it is probably
best to force static linking whenever possible at least where tutorials
are concerned as you can eliminate issues with finding shared libs.
On Fri, 2008-11-07 at 20:21, isenburg1 at llnl.gov wrote:
> hi ryan,
> i tried running your tutorial. there is some issue with libhdf5.so.0
> libraries. are they missing or is an obvious path missing?
> isenburg at mesh:~/FronTier_tutorial$ ./HelloFronTier
> isenburg at mesh:~/FronTier_tutorial$ echo $LD_LIBRARY_PATH
> /usr/local/itaps/FMDB_iMeshP/lib/
> isenburg at mesh:~/FronTier_tutorial$  export
> LD_LIBRARY_PATH=/usr/local/itaps/MOABser/lib:${LD_LIBRARY_PATH}
> /usr/local/itaps/MOABser/lib:/usr/local/itaps/FMDB_iMeshP/lib/
> cheers
> martin
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
