itaps-parallel FronTier tutorial
isenburg1 at llnl.gov isenburg1 at llnl.gov
Fri Nov 7 22:21:21 CST 2008
hi ryan,
i tried running your tutorial. there is some issue with libhdf5.so.0
libraries. are they missing or is an obvious path missing?
isenburg at mesh:~/FronTier_tutorial$ ./HelloFronTier
./HelloFronTier: error while loading shared libraries: libiMesh.so.0:
cannot open shared object file: No such file or directory
isenburg at mesh:~/FronTier_tutorial$ echo $LD_LIBRARY_PATH
/usr/local/itaps/FMDB_iMeshP/lib/
isenburg at mesh:~/FronTier_tutorial$  export
LD_LIBRARY_PATH=/usr/local/itaps/MOABser/lib:${LD_LIBRARY_PATH}
/usr/local/itaps/MOABser/lib:/usr/local/itaps/FMDB_iMeshP/lib/
./HelloFronTier: error while loading shared libraries: libhdf5.so.0:
cheers
martin
More information about the itaps-parallel mailing list
