itaps-parallel FMDB libraries are updated on mesh machine
Vitus Leung
vjleung at sandia.gov
Wed Nov 5 14:37:01 CST 2008
Lori,
It seems to be an intermittent problem. I just compiled it again.
Vitus
On Wed, 2008-11-05 at 11:48 -0700, Lori A. Diachin wrote:
> I think I came across this as well - Vitus, what did you do to get it
> compile?
> Lori
> Vitus Leung wrote:
> > Ting,
> > I think I may have come across that already. I did manage to eventually
> > compile.
> > Vitus
> > On Wed, 2008-11-05 at 10:58 -0700, txie at scorec.rpi.edu wrote:
> >> Hi all,
> >> I just worked with Alex on the mesh adaptivity example, and found the
> >> latest FMDB_iMeshP version may (or may not) cause name mangling errors
> >> during compiling. I will check this problem, and let you know once I
> >> finish.
> >> Thanks for your patience.
> >> Ting
> >>> Hi all,
> >>> I'll copy everything over to the other machine sometime tomorrow
> >>> before noon. I've already copied most things once (yesterday). I'm
> >>> only copying what's under /usr/local/itaps; if you want something else
> >>> copied too, let me know.
> >>> - tim
> >>>> Hi all,
> >>>> I just updated FMDB libraries on mesh machine (Tim's machine) based on
> >>>> the
> >>>> latest iMeshP.h version. The main modifications are name changes on some
> >>>> iMeshP functions. The paths to the libraries are:
> >>>> /usr/local/itaps/FMDB_iMeshP/ (iMeshP enabled, for parallel)
> >>>> /usr/local/itaps/FMDB_iMesh/ (iMesh enabled, for serial)
> >>>> Please see the following changes from Karen's last email, and make sure
> >>>> that your program still works if it uses FMDB_iMeshP. Also let me know
> >>>> if you find any problems. Thanks.
> >>>> Ting
> >>>>> Changes:
> >>>>> - Reformatted many, many, many comments for Doxygen. (Anyone feel
> >>>>> like
> >>>>> proofreading??)
> >>>>> - Changed function names for consistency with our conventions:
> >>>>> iMeshP_Wait -> iMeshP_waitForRequest
> >>>>> iMeshP_WaitAll -> iMeshP_waitForAllRequests
> >>>>> iMeshP_WaitAny -> iMeshP_waitForAnyRequest
> >>>>> iMeshP_WaitEnt -> iMeshP_waitForRequestEnt
> >>>>> iMeshP_Test -> iMeshP_testRequest
> >>>>> iMeshP_load -> iMeshP_loadAll
> >>>>> iMeshP_save -> iMeshP_saveAll
> >>>>> iMeshP_createGhostEnts -> iMeshP_createGhostEntsAll
> >>>>> iMeshP_deleteGhostEnts -> iMeshP_deleteGhostEntsAll
> >>>>> - Removed iMeshP_Status from the interface; it was defined only as a
> >>>>> handle, and we didn't give the apps a way to access any of its data.
> >>>>> - Removed some "const" keywords where I thought they didn't make
> >>>>> sense.
> >>>>> - Removed redundant argument num_ghost_rules from
> >>>>> iMeshP_getGhostEntInfo.
> >>>>> - In iMeshP_pushTags and its siblings, change the tag argument to a
> >>>>> source-tag argument; added a destination tag argument.
> >>>>> Out-standing questions and things to do:
> >>>>> - In iMeshP_exchEntArrToPartsAll, what are implementations using for
> >>>>> the
> >>>>> command_code? Should I make this an enumerated type? Or just
> >>>>> "yes/no"
> >>>>> for
> >>>>> migration? (Yes == migrate entity, no == create only a copy).
> >>>>> - In iMeshP_exchEntArrToPartsAll, how are implementations interpreting
> >>>>> the
> >>>>> update_ghost argument?
> >>>>> - In iMeshP_exchEntArrToPartsAll, what adjacencies are being migrated
> >>>>> with
> >>>>> the entities in the arguments? Downward adjacencies only? Is the
> >>>>> ownership
> >>>>> of the downward adjacencies automatically changed to something that
> >>>>> "makes
> >>>>> sense"? (I think Ting raised this issue before but I don't recall that
> >>>>> we
> >>>>> resolved her questions.)
> >>>>> - How is the offset array in iMeshP_replaceOnPartBdry used? I guessed
> >>>>> the
> >>>>> following; Onkar, let me know if it is correct. If it is correct, do
> >>>>> we
> >>>>> need offset_size?
> >>>>> offset (In) Index into new_entities; old_entities[i]
> >>>>> is replaced by new_entities[offset[i]] to
> >>>>> new_entities[offset[i+1]-1].
> >>>>> - Resolve Jason's recent questions about creating ghost entities.
> >>>>> - Add functions to either pull or accumulate tag data as proposed by
> >>>>> Jason.
> >>>>> - Update iMeshP functions to reflect changes in iMesh, if any, to
> >>>>> iMesh_getAllVtxCoords and iMesh_getVtxCoordIndex as outlined by Jason.
> >>>>> Karen
> >>> "You will keep in perfect peace him whose mind is
> >>> steadfast, because he trusts in you." Isaiah 26:3
> >>> Tim Tautges Argonne National Laboratory
> >>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> >>> phone: (608) 263-8485 1500 Engineering Dr.
> >>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
