itaps-parallel FMDB libraries are updated on mesh machine
txie at scorec.rpi.edu
Wed Nov 5 13:57:46 CST 2008
Hi all,
I have fixed that problem, and updated the FMDB_iMeshP libraries. Please
let me know if you still have problems using them.
Ting
> Hi Lori,
> The main problem is that some iMeshP function names in the latest
> FMDB_iMeshP version are changed. If your code does not use those
> functions, you will not get the name mangling problems during compiling.
> I will fix this problem very soon. Sorry about that.
> Thanks,
> Ting
>> I think I came across this as well - Vitus, what did you do to get it
>> compile?
>> Lori
>> Vitus Leung wrote:
>>> Ting,
>>> I think I may have come across that already. I did manage to
>>> eventually
>>> compile.
>>> Vitus
>>> On Wed, 2008-11-05 at 10:58 -0700, txie at scorec.rpi.edu wrote:
>>>> Hi all,
>>>> I just worked with Alex on the mesh adaptivity example, and found the
>>>> latest FMDB_iMeshP version may (or may not) cause name mangling errors
>>>> during compiling. I will check this problem, and let you know once I
>>>> finish.
>>>> Thanks for your patience.
>>>> Ting
>>>>> Hi all,
>>>>> I'll copy everything over to the other machine sometime tomorrow
>>>>> before noon. I've already copied most things once (yesterday). I'm
>>>>> only copying what's under /usr/local/itaps; if you want something
>>>>> else
>>>>> copied too, let me know.
>>>>> - tim
>>>>>> Hi all,
>>>>>> I just updated FMDB libraries on mesh machine (Tim's machine) based
>>>>>> on
>>>>>> the
>>>>>> latest iMeshP.h version. The main modifications are name changes on
>>>>>> some
>>>>>> iMeshP functions. The paths to the libraries are:
>>>>>> /usr/local/itaps/FMDB_iMeshP/ (iMeshP enabled, for parallel)
>>>>>> /usr/local/itaps/FMDB_iMesh/ (iMesh enabled, for serial)
>>>>>> Please see the following changes from Karen's last email, and make
>>>>>> sure
>>>>>> that your program still works if it uses FMDB_iMeshP. Also let me
>>>>>> know
>>>>>> if you find any problems. Thanks.
>>>>>> Ting
>>>>>>> Changes:
>>>>>>> - Reformatted many, many, many comments for Doxygen. (Anyone feel
>>>>>>> like
>>>>>>> proofreading??)
>>>>>>> - Changed function names for consistency with our conventions:
>>>>>>> iMeshP_Wait -> iMeshP_waitForRequest
>>>>>>> iMeshP_WaitAll -> iMeshP_waitForAllRequests
>>>>>>> iMeshP_WaitAny -> iMeshP_waitForAnyRequest
>>>>>>> iMeshP_WaitEnt -> iMeshP_waitForRequestEnt
>>>>>>> iMeshP_Test -> iMeshP_testRequest
>>>>>>> iMeshP_load -> iMeshP_loadAll
>>>>>>> iMeshP_save -> iMeshP_saveAll
>>>>>>> iMeshP_createGhostEnts -> iMeshP_createGhostEntsAll
>>>>>>> iMeshP_deleteGhostEnts -> iMeshP_deleteGhostEntsAll
>>>>>>> - Removed iMeshP_Status from the interface; it was defined only as
>>>>>>> a
>>>>>>> handle, and we didn't give the apps a way to access any of its
>>>>>>> data.
>>>>>>> - Removed some "const" keywords where I thought they didn't make
>>>>>>> sense.
>>>>>>> - Removed redundant argument num_ghost_rules from
>>>>>>> iMeshP_getGhostEntInfo.
>>>>>>> - In iMeshP_pushTags and its siblings, change the tag argument to
>>>>>>> a
>>>>>>> source-tag argument; added a destination tag argument.
>>>>>>> Out-standing questions and things to do:
>>>>>>> - In iMeshP_exchEntArrToPartsAll, what are implementations using
>>>>>>> for
>>>>>>> the
>>>>>>> command_code? Should I make this an enumerated type? Or just
>>>>>>> "yes/no"
>>>>>>> for
>>>>>>> migration? (Yes == migrate entity, no == create only a copy).
>>>>>>> - In iMeshP_exchEntArrToPartsAll, how are implementations
>>>>>>> interpreting
>>>>>>> the
>>>>>>> update_ghost argument?
>>>>>>> - In iMeshP_exchEntArrToPartsAll, what adjacencies are being
>>>>>>> migrated
>>>>>>> with
>>>>>>> the entities in the arguments? Downward adjacencies only? Is the
>>>>>>> ownership
>>>>>>> of the downward adjacencies automatically changed to something that
>>>>>>> "makes
>>>>>>> sense"? (I think Ting raised this issue before but I don't recall
>>>>>>> that
>>>>>>> we
>>>>>>> resolved her questions.)
>>>>>>> - How is the offset array in iMeshP_replaceOnPartBdry used? I
>>>>>>> guessed
>>>>>>> the
>>>>>>> following; Onkar, let me know if it is correct. If it is correct,
>>>>>>> do
>>>>>>> we
>>>>>>> need offset_size?
>>>>>>> offset (In) Index into new_entities; old_entities[i]
>>>>>>> is replaced by new_entities[offset[i]] to
>>>>>>> new_entities[offset[i+1]-1].
>>>>>>> - Resolve Jason's recent questions about creating ghost entities.
>>>>>>> - Add functions to either pull or accumulate tag data as proposed
>>>>>>> by
>>>>>>> Jason.
>>>>>>> - Update iMeshP functions to reflect changes in iMesh, if any, to
>>>>>>> iMesh_getAllVtxCoords and iMesh_getVtxCoordIndex as outlined by
>>>>>>> Jason.
>>>>>>> Karen
>>>>> "You will keep in perfect peace him whose mind is
>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>> Tim Tautges Argonne National Laboratory
>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
