itaps-parallel tutorial comments
isenburg1 at llnl.gov isenburg1 at llnl.gov
Wed Nov 5 16:11:36 CST 2008
hello vitus,
i just tried out your tutorial. works great .. i had just a few
hickups (see below)! i think your "Zoltan" would be a good fit after
"Hello" and before "Smooth". Maybe you could create a single directory
for the two exercises similar to the structure of "Hello" and "Smooth" ?
below are my comments for the two tutorials
cheers
martin
comments for tutorial1
- in EXERCISE 3 it took me  while to figure out to use argv[2]
- when i type 'make' it wrongly tells me
    "To build the iMeshPZoltan C++ test program, type
       gmake ZOLTAN_ARCH=desired_arch fmdbzoltan"
- you should add the following variables to EXCERCISE 4 unless you
left them out on purpose
   int parts_size, parts_allocated = 0;
- in the Hands_on file it should say to run. not the added './'
   mpirun -np 4 ./fmdbzoltan 4 part.sms REGION tmp
comments for tutorial2
- change comment "delete the partition" to "destroy the partition"
- change comment "delete the part" to "destroy the part"
- if the user does not use "VTK" as option in iMeshP_saveAll and then runs
    mpirun -np 4 ./fmdbzoltan 4 part.sms REGION repart
the code crashes. instead the user should call
   mpirun -np 4 ./fmdbzoltan 4 part.sms REGION repart.sms
which will work either way.
More information about the itaps-parallel mailing list
