[hpc-announce] Auto-DaSP 2019 Workshop at Euro-Par 2019
Valeria Cardellini
cardellini at ing.uniroma2.it
Mon Apr 29 02:10:37 CDT 2019
Auto-DaSP 2019: Euro-Par 2019 International Workshop
Autonomic Solutions for Parallel and Distributed Data Stream Processing
Date: 26-27, August 2019
Workshop web page: http://www.di.unipi.it/auto-dasp-19/
Euro-Par web page: http://2019.euro-par.org/
* Call for Papers
The ever-growing expansion of smart devices and sensors increases the amount
of data flows that have to be processed in real-time. This extends to a wide
spectrum of applications with high socio-economic impact, like systems for
healthcare, emergency management, surveillance, intelligent transportation
and many others.
Data Stream Processing systems (DSPs) usually get in input high-volume of data
at high frequency, and process the application queries by respecting strict
performance requirements in terms of throughput and response time.
The maintenance of these constraints is often fundamental despite an unplanned
or unexpected workload variability or changes due to the dynamism of the
execution environment.
High-volume data streams can be efficiently handled through the adoption of novel
high-performance solutions targeting today's highly parallel hardware.
This comprises multicore-based platforms and heterogeneous systems equipped with
GPU and FPGA co-processors, aggregated at rack level by low-latency/high-bandwidth
networks. The capacity of these highly-dense/highly-parallel rack-scale solutions
has grown remarkably over the years, offering tens of thousands of heterogeneous
cores and multiple terabytes of aggregated RAM reaching computing, memory and
storage capacity of a large warehouse-scale cluster of just few years ago.
However, despite this large computing power, high-performance data streaming
solutions need to be equipped with flexible and autonomic logics in order to adapt
the framework/application configuration to rapidly changing execution conditions
and workloads. This turns out in mechanisms and strategies to adapt the queries
and operator placement policies, intra-operator parallelism degree, scheduling
strategies, load shedding rate and so forth, and fosters novel interdisciplinary
approaches that exploit Control Theory and Artificial Intelligence methods.
The Auto-DaSP workshop is willing to attract contributions in the area of
Data Stream Processing with particular emphasis on supports for highly parallel
platforms and autonomic features to deal with variable workloads.
A partial list of interesting topics of this workshop is the following:
- Parallel models for streaming applications
- Parallel sliding-window query processing
- Streaming parallel patterns
- Autonomic intra-operator parallel solutions
- Strategies for dynamic operator and query placement
- Elastic techniques to cope with burstiness and workload variations
- Integration of elasticity support in stream processing frameworks
- Stream processing on heterogeneous and reconfigurable hardware
- Stream scheduling strategies and load balancing
- Adaptive load shedding techniques
- Techniques to deal with out-of-order data streams
- Power- and energy-aware management of parallel stream processing systems
- Applications and use cases in various domains including Smart Cities, IoT,
Finance, Social Media, and Healthcare
* Submission Instructions
Submissions in PDF format should be between 10-12 pages in the Springer LNCS style,
which can be downloaded from the Springer Web site. The 12 pages limit is a hard limit
while the minimum bound of 10 pages is needed to see the paper published in the formal
Springer proceedings. It includes everything (text, figures, references) and will be
strictly enforced by the submission system. Complete LaTeX sources must be provided
for accepted papers. All submitted research papers will be peer-reviewed.
Only contributions that are not submitted elsewhere or currently under review will
be considered. Accepted papers will be included in the workshop proceedings, published
by Springer in the ARCoSS/LNCS series.
Authors of accepted papers will have to sign a Springer copyright form.
* Papers have to be submitted through EasyChair using the following link:
https://easychair.org/conferences/?conf=europar2019workshops
* Special Issue
To be announced.
* Important Dates
May 10, 2019 Paper submission deadline
June 28, 2019 Paper acceptance notifications
July 22, 2019 Camera-ready due (informal proceedings)
September 27, 2019 Camera-ready due
August 26-27, 2019 Workshop days (exact date not decided, yet)
* Workshop Co-Chairs
- Valeria Cardellini, University of Rome Tor Vergata, Italy
- Gabriele Mencagli, University of Pisa, Italy
- Massimo Torquati, University of Pisa, Italy
If you have any questions about paper submission or the workshop, please contact the workshop organizers.
Best regards,
Valeria Cardellini, Gabriele Mencagli and Massimo Torquati
More information about the hpc-announce
