[hpc-announce] COSH 2018: Call for Papers - 3rd Workshop on Co-Scheduling of HPC Applications
Josef Weidendorfer
Josef.Weidendorfer at in.tum.de
Mon Oct 16 08:00:42 CDT 2017
CALL FOR PAPERS
(COSH 2018)
Manchester, UK, January 23, 2018
together with HiPEAC 2018
http://wwwi10.lrr.in.tum.de/~trinitic/COSH2018
BACKGROUND
The task of a high performance computing system is to carry out its
calculations (mainly scientific applications) with maximum performance
and energy efficiency. Up until now, this goal could only be achieved
by exclusively assigning an appropriate number of cores/nodes to
parallel applications. As a consequence, applications had to be highly
optimised in order to achieve even only a fraction of a
supercomputer's peak performance which required huge efforts on the
programmer side. This problem is expected to become more serious on
future exascale systems with millions of compute cores. Many of
today's highly scalable applications will not be able to utilise an
exascale system's extreme parallelism due to node specific limitations
like e.g. I/O bandwidth. Therefore, to be able to efficiently use
future supercomputers, it will be necessary to simultaneously run more
than one application on a node. To be able to efficiently perform
co-scheduling, applications must not slow down each other,
i.e. candidates for co-scheduling could e.g. be a memory-bound and a
compute bound application.
Within this context, it might also be necessary to dynamically migrate
applications between nodes if e.g. a new application is scheduled to
the system. In order to be able to monitor performance and energy
efficiency during operation, additional sensors are required. These
need to be correlated to running applications to deliver values for
key performance indicators.
Thus, submitted papers should cover one or more items from the
following research areas:
* novel scheduling strategies using co-scheduling
* co-scheduling towards energy efficiency
* case studies involving co-scheduling
* application characterisation for co-scheduling
* using performance sensors to guide co-scheduling
* resource re-assignment / task migration enabling co-scheduling
* throughput studies for supercomputers using co-scheduling
IMPORTANT DATES
Paper submission deadline: November 27, 2017
Notification: December 12, 2017
Camera ready: December 20, 2017
COSH Workshop: January 23, 2018
SUBMISSION GUIDELINES
All papers must be original and not simultaneously submitted to
another journal or conference. Workshop papers must not exceed 6
single-spaced, double-column pages in ACM style (including figures and
references). On acceptance, one author of each paper must present the
paper in the workshop. Submit your paper here:
https://easychair.org/conferences/?conf=cosh2018
The COSH2018 proceedings will be published online in TUM Library.
All questions about submissions should be emailed to Carsten Trinitis.
ORGANIZATION
Programme Committee
TBD (updated on web page)
Organising Committee
Carsten Trinitis, Technische Universität München, Germany
Josef Weidendorfer, Technische Universität München, Germany
VENUE
The conference will be held in Manchester, United Kingdom, EU, at the
Manchester Central Convention Centre. COSH 2018 will be co-located with
HiPEAC 2018.
Josef Weidendorfer, Informatik, Technische Universität München
TUM I-10 - FMI 01.04.035 - Tel. 089 / 289-18454
More information about the hpc-announce
