[ExM Users] Swift/T using wrong Python
Tim Armstrong
tim.g.armstrong at gmail.com
Sun Apr 19 21:21:18 CDT 2015
Hmm, so it's probably picking up the system Python by default. This may
be an oversight on our part - I'm creating a bug to look into it. Our
build should be linking it to your other python library but isn't.
As a workaround, you can override this with the DYLD_LIBRARY_PATH
environment variable on Mac OS X.
If you add the directory with your preferred python .dylib file to that
environment variable, it should link against that version of python instead
of the system one.
E.g.
export DYLD_LIBRARY_PATH=/path/to/anaconda/lib
I *think* this should give you a way to work around it in the meantime.
- Tim
On 19 April 2015 at 20:19, Ozik, Jonathan <jozik at anl.gov> wrote:
> Thanks Tim. Here’s what I get on OS X:
> XioMBP:swift_simphony_example_DEAP jozik$ otool
> -L /Users/jozik/work/swift_t/install/turbine/lib/libtclturbine.dylib
> /Users/jozik/work/swift_t/install/turbine/lib/libtclturbine.dylib:
> (compatibility version 0.0.0, current version 0.0.0)
> /Users/jozik/work/swift_t/install/lb/lib/libadlb.dylib (compatibility
> /Users/jozik/work/swift_t/install/c-utils/lib/libexmcutils.dylib
> /usr/local/opt/tcl-tk/lib/libtcl8.6.dylib (compatibility version 8.6.0,
> current version 8.6.3)
> /usr/local/lib/libmpi.12.dylib (compatibility version 13.0.0, current
> version 13.4.0)
> libpython2.7.dylib (compatibility version 2.7.0, current version 2.7.0)
> libz.1.dylib (compatibility version 1.0.0, current version 1.2.8)
> /usr/local/lib/libsz.2.dylib (compatibility version 3.0.0, current version
> 3.0.0)
> /usr/local/lib/libhdf5.8.dylib (compatibility version 9.0.0, current
> version 9.2.0)
> /usr/local/lib/libhdf5_hl.8.dylib (compatibility version 9.0.0, current
> version 9.2.0)
> /usr/local/lib/libpmpi.12.dylib (compatibility version 13.0.0, current
> version 13.4.0)
> /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version
> 1213.0.0)
> /usr/local/Cellar/gcc/4.9.2/lib/gcc/x86_64-apple-darwin14.0.0/4.9.2/libgcc_s.1.dylib (compatibility
> version 1.0.0, current version 1.0.0)
> Which doesn’t answer our question of which libpython2.7.dylib is being
> linked to… If there’s a build log file that you want to point me to, I can
> do some more digging.
> Jonathan
> On Apr 19, 2015, at 7:36 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
> It might be helpful to get some linker information from your
> installation to see which Python version it's linking against.
> In linux:
> ldd /path/to/turbine/lib/libtclturbine.so
> In OS X I think it's something like:
> otool -L /path/to/turbine/lib/libtclturbine.dylib
> - Tim
> On 19 April 2015 at 15:55, Ozik, Jonathan <jozik at anl.gov> wrote:
>> An update. I looked to see whether this was a PATH issue, and saw that
>> there was a difference between how my bash and zsh shells populate the PATH
>> variable. I have made them compatible now, but am still seeing the same
>> issue with the wrong python being picked up.
>> Jonathan
>> > On Apr 18, 2015, at 11:21 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>> > Hi all,
>> > I’ve run up against an issue where Swift/T’s python and python_persist
>> are using the wrong Python version. I’ve checked and rebuilt and it looks
>> like the Python install location specified in exm-settings.sh is being used
>> in the build log but when I run a simple test:
>> > string ss = python_persist("import sys\nsys.version”);
>> > I’m getting the Python installation at /usr/bin/python rather than the
>> Python version installed as part of the Anaconda distribution (which is
>> what the exm-settings.sh is configured to use).
>> > Any advice on how I might better diagnose this would be appreciated.
>> I’m on Mac OS X (10.10.3).
>> > Jonathan
>> > _______________________________________________
>> > ExM-user mailing list
>> > ExM-user at lists.mcs.anl.gov
>> > https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20150419/4b28b909/attachment.html>
More information about the ExM-user
