[ExM Users] TCLLIBPATH reset?
Tim Armstrong
tim.g.armstrong at gmail.com
Thu Sep 25 10:15:57 CDT 2014
With Swift 0.6.1 you can set the Tcl library path via TURBINE_USER_LIB.
I.e. instead of TCLLIBPATH, you should add those directories to
TURBINE_USER_LIB
- Tim
On Thu, Sep 25, 2014 at 9:48 AM, Ozik, Jonathan <jozik at anl.gov> wrote:
> Hello,
> I’m getting an issue where packages can’t be found. When launching turbine
> with the -V option I see that the TCLLIBPATH is being set via:
> ++ TCLLIBPATH=
> ++ [[ -n '' ]]
> ++ (( EXEC_SCRIPT ))
> ++ (( TURBINE_STATIC_EXEC ))
> ++ (( !TURBINE_PKG_AVAIL ))
> ++ [[ /usr/local/Cellar/tcl-tk/8.6.1/bin/tclsh8.6 == '' ]]
> ++ TCLLIBPATH+=/Users/jozik/work/swift_t/install/turbine/lib
> ++ export TCLLIBPATH
> which suggests to me that setting it to look at where a pkgIndex.tcl is
> located prior to launching turbine is overwritten? Is there a command line
> option that I should be sending to turbine to include custom pkgIndex.tcl
> locations?
> Jonathan
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140925/717a6057/attachment.html>
More information about the ExM-user
