[ExM Users] TCLLIBPATH reset?
Ozik, Jonathan
jozik at anl.gov
Thu Sep 25 10:24:46 CDT 2014
Tim, Justin,
Thank you. I missed that.
Jonathan
On Sep 25, 2014, at 10:15 AM, Tim Armstrong <tim.g.armstrong at gmail.com<mailto:tim.g.armstrong at gmail.com>> wrote:
With Swift 0.6.1 you can set the Tcl library path via TURBINE_USER_LIB. I.e. instead of TCLLIBPATH, you should add those directories to TURBINE_USER_LIB
- Tim
On Thu, Sep 25, 2014 at 9:48 AM, Ozik, Jonathan <jozik at anl.gov<mailto:jozik at anl.gov>> wrote:
Hello,
I’m getting an issue where packages can’t be found. When launching turbine with the -V option I see that the TCLLIBPATH is being set via:
++ TCLLIBPATH=
++ [[ -n '' ]]
++ (( EXEC_SCRIPT ))
++ (( TURBINE_STATIC_EXEC ))
++ (( !TURBINE_PKG_AVAIL ))
++ [[ /usr/local/Cellar/tcl-tk/8.6.1/bin/tclsh8.6 == '' ]]
++ TCLLIBPATH+=/Users/jozik/work/swift_t/install/turbine/lib
++ export TCLLIBPATH
which suggests to me that setting it to look at where a pkgIndex.tcl is located prior to launching turbine is overwritten? Is there a command line option that I should be sending to turbine to include custom pkgIndex.tcl locations?
Jonathan
ExM-user mailing list
ExM-user at lists.mcs.anl.gov<mailto:ExM-user at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140925/c3ed2a80/attachment.html>
More information about the ExM-user
