[ExM Users] Turbine build failed
Ozik, Jonathan
jozik at anl.gov
Mon Sep 8 12:57:40 CDT 2014
Justin,
I modified this line in exm-setup.zsh:
${RELEASE}/build/turbine-build.sh --disable-static-pkg
I’m still seeing the same errors.
Jonathan
On Sep 8, 2014, at 12:12 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> Hi
> I have not seen that error. Can you configure Turbine to build with --disable-static-pkg and try again? (You do this by editing exm-setup.zsh .)
> Justin
> On 09/08/2014 12:05 PM, Ozik, Jonathan wrote:
>> Hello all,
>> I’m trying to set up a local installation of Swift/T on Mac OS X. Following the instructions in the user guide (http://swift-lang.org/Swift-T/guide.html#_installation) and downloading the latest stable version (http://swift-lang.org/Swift-T/downloads/exm-0.6.1.tar.gz) I’ve gotten the c-utils and lb building with only the EXM_PREFIX line modified in exm-settings.sh but I’m getting a build failed error on the turbine build. The only errors that are showing up are 2 instances of:
>> mkstatic: error: could not convert tcl file /usr/local/Cellar/tcl-tk/8.6.1/lib/tcl8.6/init.tcl to C array
>> If you have any insight as to what is causing the build fail or can suggest some things to try I’d appreciate it.
>> Jonathan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
More information about the ExM-user
