[ExM Users] Turbine build failed
Justin M Wozniak
wozniak at mcs.anl.gov
Mon Sep 8 12:12:16 CDT 2014
Hi
I have not seen that error. Can you configure Turbine to build
with --disable-static-pkg and try again? (You do this by editing
exm-setup.zsh .)
Justin
On 09/08/2014 12:05 PM, Ozik, Jonathan wrote:
> Hello all,
> I’m trying to set up a local installation of Swift/T on Mac OS X. Following the instructions in the user guide (http://swift-lang.org/Swift-T/guide.html#_installation) and downloading the latest stable version (http://swift-lang.org/Swift-T/downloads/exm-0.6.1.tar.gz) I’ve gotten the c-utils and lb building with only the EXM_PREFIX line modified in exm-settings.sh but I’m getting a build failed error on the turbine build. The only errors that are showing up are 2 instances of:
> mkstatic: error: could not convert tcl file /usr/local/Cellar/tcl-tk/8.6.1/lib/tcl8.6/init.tcl to C array
> If you have any insight as to what is causing the build fail or can suggest some things to try I’d appreciate it.
> Jonathan
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
More information about the ExM-user
