[ExM Users] Turbine build failed
Tim Armstrong
tim.g.armstrong at gmail.com
Mon Sep 8 12:58:20 CDT 2014
If you have a chance, could you try running this command from the unpacked
tarball directory and seeing what the output is:
./turbine/scripts/mkstatic/file2array.sh -v var -m "static const"
/usr/local/Cellar/tcl-tk/8.6.1/lib/tcl8.6/init.tcl
If you get something about "mktemp", you could try making this change to
./turbine/scripts/mkstatic/file2array.sh:
-data=$(mktemp)
+data=$(mktemp -t FILE2ARRAY)
Justin, it looks like the fix from -r13616 isn't in the 0.6.2 release.
- Tim
On Mon, Sep 8, 2014 at 12:12 PM, Justin M Wozniak <wozniak at mcs.anl.gov>
wrote:
> Hi
> I have not seen that error. Can you configure Turbine to build with
> --disable-static-pkg and try again? (You do this by editing exm-setup.zsh
> Justin
> On 09/08/2014 12:05 PM, Ozik, Jonathan wrote:
>> Hello all,
>> I’m trying to set up a local installation of Swift/T on Mac OS X.
>> Following the instructions in the user guide (
>> http://swift-lang.org/Swift-T/guide.html#_installation) and downloading
>> the latest stable version (http://swift-lang.org/Swift-
>> T/downloads/exm-0.6.1.tar.gz) I’ve gotten the c-utils and lb building
>> with only the EXM_PREFIX line modified in exm-settings.sh but I’m getting a
>> build failed error on the turbine build. The only errors that are showing
>> up are 2 instances of:
>> mkstatic: error: could not convert tcl file /usr/local/Cellar/tcl-tk/8.6.1/lib/tcl8.6/init.tcl
>> to C array
>> If you have any insight as to what is causing the build fail or can
>> suggest some things to try I’d appreciate it.
>> Jonathan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140908/9f85ba8a/attachment.html>
More information about the ExM-user
