[ExM Users] Running on Vesta
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Nov 4 12:00:19 CST 2014
On 11/04/2014 11:56 AM, Ozik, Jonathan wrote:
> Thanks Justin, very helpful.
> It looks like the swift-t executable doesn’t have read permissions.
Oops try now.
> Also, is there a way I could get the trunk version to build on my local machine for local testing?
We should have a release out later this week.
> Jonathan
>> On Nov 4, 2014, at 10:03 AM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>> Yes, use the turbine -i flag to run an initialization script:
>> http://swift-lang.org/Swift-T/turbine-sites.html#options
>> Create a shell script (say, ~/p.sh):
>> #!/bin/sh
>> cp -v ~/data.txt $TURBINE_OUTPUT
>> You can use this with turbine-cobalt-run or with the new swift-t interface like this:
>> swift-t -m cobalt -t i:$HOME/p.sh ~/p.swift
>> The output is:
>> TURBINE-COBALT SCRIPT
>> TURBINE_OUTPUT=/home/wozniak/turbine-output/2014/11/04/09/57/13
>> executing: /home/wozniak/p.sh
>> `/home/wozniak/data.txt' -> `/home/wozniak/turbine-output/2014/11/04/09/57/13/data.txt'
>> done: /home/wozniak/p.sh
>> JOB_ID...
>> swift-t -t is used to pass the -i p.sh argument through to Turbine.
>> The swift-t interface is new and not yet documented but it basically supports the previously defined stc and turbine arguments.
>> On 11/3/2014 11:21 PM, Ozik, Jonathan wrote:
>>> Thanks Justin.
>>> Is there an easy way to transfer input files to the working directory that’s used? Is it just a matter of specifying a working directory for execution or is there a better way?
>>> Jonathan
>>>> On Nov 3, 2014, at 9:37 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>> Ok, it's ready to try. Since this is based on trunk, you can use the latest command-line interface:
>>>> $ PATH=/home/wozniak/Public/sfw/stc/bin:$PATH
>>>> $ export MODE=BGQ QUEUE=default PROJECT=ExM
>>>> $ swift-t -m cobalt ~/p.swift
>>>> On 11/3/2014 9:18 PM, Ozik, Jonathan wrote:
>>>>> Sounds great. Thanks!
>>>>>> On Nov 3, 2014, at 9:10 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>> Vesta was down for maintenance today- I'll get back to you tomorrow.
>>>>>> On 11/3/2014 6:12 PM, Ozik, Jonathan wrote:
>>>>>>> Hi all,
>>>>>>> I’m following up on the public stc and turbine builds on Vesta. Any luck on those?
>>>>>>> Thanks as always,
>>>>>>> Jonathan
>>>>>>>> On Oct 31, 2014, at 2:06 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>>>>> That would be great. Please let me know if I can help out with anything.
>>>>>>>> Jonathan
>>>>>>>>> On Oct 31, 2014, at 2:04 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>>>>> I can set you up with one.
>>>>>>>>> On 10/31/2014 01:52 PM, Ozik, Jonathan wrote:
>>>>>>>>>> Hello all,
>>>>>>>>>> I’m trying to run some simple scripts on Vesta and was wondering if there are more recent publicly available stc and turbine builds than the ones under /home/wozniak/Public ?
>>>>>>>>>> Jonathan
>>>>>>>>>> _______________________________________________
>>>>>>>>>> ExM-user mailing list
>>>>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>>>> Justin M Wozniak
>>>>>> Justin M Wozniak
>>>> Justin M Wozniak
>> Justin M Wozniak
Justin M Wozniak
More information about the ExM-user
