[ExM Users] Running on Vesta
Ozik, Jonathan jozik at anl.gov
Tue Nov 4 11:56:07 CST 2014
Thanks Justin, very helpful.
It looks like the swift-t executable doesn’t have read permissions.
Also, is there a way I could get the trunk version to build on my local machine for local testing?
Jonathan
> On Nov 4, 2014, at 10:03 AM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> Yes, use the turbine -i flag to run an initialization script:
> http://swift-lang.org/Swift-T/turbine-sites.html#options
> Create a shell script (say, ~/p.sh):
> #!/bin/sh
> cp -v ~/data.txt $TURBINE_OUTPUT
> You can use this with turbine-cobalt-run or with the new swift-t interface like this:
> swift-t -m cobalt -t i:$HOME/p.sh ~/p.swift
> The output is:
> TURBINE-COBALT SCRIPT
> TURBINE_OUTPUT=/home/wozniak/turbine-output/2014/11/04/09/57/13
> executing: /home/wozniak/p.sh
> `/home/wozniak/data.txt' -> `/home/wozniak/turbine-output/2014/11/04/09/57/13/data.txt'
> done: /home/wozniak/p.sh
> JOB_ID...
> swift-t -t is used to pass the -i p.sh argument through to Turbine.
> The swift-t interface is new and not yet documented but it basically supports the previously defined stc and turbine arguments.
> On 11/3/2014 11:21 PM, Ozik, Jonathan wrote:
>> Thanks Justin.
>> Is there an easy way to transfer input files to the working directory that’s used? Is it just a matter of specifying a working directory for execution or is there a better way?
>> Jonathan
>>> On Nov 3, 2014, at 9:37 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>> Ok, it's ready to try.  Since this is based on trunk, you can use the latest command-line interface:
>>> $ PATH=/home/wozniak/Public/sfw/stc/bin:$PATH
>>> $ export MODE=BGQ QUEUE=default PROJECT=ExM
>>> $ swift-t -m cobalt ~/p.swift
>>> On 11/3/2014 9:18 PM, Ozik, Jonathan wrote:
>>>> Sounds great. Thanks!
>>>>> On Nov 3, 2014, at 9:10 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>> Vesta was down for maintenance today- I'll get back to you tomorrow.
>>>>> On 11/3/2014 6:12 PM, Ozik, Jonathan wrote:
>>>>>> Hi all,
>>>>>> I’m following up on the public stc and turbine builds on Vesta. Any luck on those?
>>>>>> Thanks as always,
>>>>>> Jonathan
>>>>>>> On Oct 31, 2014, at 2:06 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>>>> That would be great. Please let me know if I can help out with anything.
>>>>>>> Jonathan
>>>>>>>> On Oct 31, 2014, at 2:04 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>>>> I can set you up with one.
>>>>>>>> On 10/31/2014 01:52 PM, Ozik, Jonathan wrote:
>>>>>>>>> Hello all,
>>>>>>>>> I’m trying to run some simple scripts on Vesta and was wondering if there are more recent publicly available stc and turbine builds than the ones under /home/wozniak/Public ?
>>>>>>>>> Jonathan
>>>>>>>>> _______________________________________________
>>>>>>>>> ExM-user mailing list
>>>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>>> Justin M Wozniak
>>>>> Justin M Wozniak
>>> Justin M Wozniak
> Justin M Wozniak
More information about the ExM-user mailing list
