[ExM Users] Running on Vesta
Ozik, Jonathan
jozik at anl.gov
Tue Nov 4 18:58:18 CST 2014
Thanks Justin, this works now. Looking forward to the imminent release!
Jonathan
> On Nov 4, 2014, at 12:00 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> On 11/04/2014 11:56 AM, Ozik, Jonathan wrote:
>> Thanks Justin, very helpful.
>> It looks like the swift-t executable doesn’t have read permissions.
> Oops try now.
>> Also, is there a way I could get the trunk version to build on my local machine for local testing?
> We should have a release out later this week.
>> Jonathan
>>> On Nov 4, 2014, at 10:03 AM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>> Yes, use the turbine -i flag to run an initialization script:
>>> http://swift-lang.org/Swift-T/turbine-sites.html#options
>>> Create a shell script (say, ~/p.sh):
>>> #!/bin/sh
>>> cp -v ~/data.txt $TURBINE_OUTPUT
>>> You can use this with turbine-cobalt-run or with the new swift-t interface like this:
>>> swift-t -m cobalt -t i:$HOME/p.sh ~/p.swift
>>> The output is:
>>> TURBINE-COBALT SCRIPT
>>> TURBINE_OUTPUT=/home/wozniak/turbine-output/2014/11/04/09/57/13
>>> executing: /home/wozniak/p.sh
>>> `/home/wozniak/data.txt' -> `/home/wozniak/turbine-output/2014/11/04/09/57/13/data.txt'
>>> done: /home/wozniak/p.sh
>>> JOB_ID...
>>> swift-t -t is used to pass the -i p.sh argument through to Turbine.
>>> The swift-t interface is new and not yet documented but it basically supports the previously defined stc and turbine arguments.
>>> On 11/3/2014 11:21 PM, Ozik, Jonathan wrote:
>>>> Thanks Justin.
>>>> Is there an easy way to transfer input files to the working directory that’s used? Is it just a matter of specifying a working directory for execution or is there a better way?
>>>> Jonathan
>>>>> On Nov 3, 2014, at 9:37 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>> Ok, it's ready to try. Since this is based on trunk, you can use the latest command-line interface:
>>>>> $ PATH=/home/wozniak/Public/sfw/stc/bin:$PATH
>>>>> $ export MODE=BGQ QUEUE=default PROJECT=ExM
>>>>> $ swift-t -m cobalt ~/p.swift
>>>>> On 11/3/2014 9:18 PM, Ozik, Jonathan wrote:
>>>>>> Sounds great. Thanks!
>>>>>>> On Nov 3, 2014, at 9:10 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>>> Vesta was down for maintenance today- I'll get back to you tomorrow.
>>>>>>> On 11/3/2014 6:12 PM, Ozik, Jonathan wrote:
>>>>>>>> Hi all,
>>>>>>>> I’m following up on the public stc and turbine builds on Vesta. Any luck on those?
>>>>>>>> Thanks as always,
>>>>>>>> Jonathan
>>>>>>>>> On Oct 31, 2014, at 2:06 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>>>>>> That would be great. Please let me know if I can help out with anything.
>>>>>>>>> Jonathan
>>>>>>>>>> On Oct 31, 2014, at 2:04 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>>>>>> I can set you up with one.
>>>>>>>>>> On 10/31/2014 01:52 PM, Ozik, Jonathan wrote:
>>>>>>>>>>> Hello all,
>>>>>>>>>>> I’m trying to run some simple scripts on Vesta and was wondering if there are more recent publicly available stc and turbine builds than the ones under /home/wozniak/Public ?
>>>>>>>>>>> Jonathan
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> ExM-user mailing list
>>>>>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>>>>> Justin M Wozniak
>>>>>>> Justin M Wozniak
>>>>> Justin M Wozniak
>>> Justin M Wozniak
> Justin M Wozniak
More information about the ExM-user
