[ExM Users] Running on Vesta
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Nov 4 10:03:46 CST 2014
Yes, use the turbine -i flag to run an initialization script:
http://swift-lang.org/Swift-T/turbine-sites.html#options
Create a shell script (say, ~/p.sh):
#!/bin/sh
cp -v ~/data.txt $TURBINE_OUTPUT
You can use this with turbine-cobalt-run or with the new swift-t
interface like this:
swift-t -m cobalt -t i:$HOME/p.sh ~/p.swift
The output is:
TURBINE-COBALT SCRIPT
TURBINE_OUTPUT=/home/wozniak/turbine-output/2014/11/04/09/57/13
executing: /home/wozniak/p.sh
`/home/wozniak/data.txt' ->
`/home/wozniak/turbine-output/2014/11/04/09/57/13/data.txt'
done: /home/wozniak/p.sh
JOB_ID...
swift-t -t is used to pass the -i p.sh argument through to Turbine.
The swift-t interface is new and not yet documented but it basically
supports the previously defined stc and turbine arguments.
On 11/3/2014 11:21 PM, Ozik, Jonathan wrote:
> Thanks Justin.
> Is there an easy way to transfer input files to the working directory that’s used? Is it just a matter of specifying a working directory for execution or is there a better way?
> Jonathan
>> On Nov 3, 2014, at 9:37 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>> Ok, it's ready to try. Since this is based on trunk, you can use the latest command-line interface:
>> $ PATH=/home/wozniak/Public/sfw/stc/bin:$PATH
>> $ export MODE=BGQ QUEUE=default PROJECT=ExM
>> $ swift-t -m cobalt ~/p.swift
>> On 11/3/2014 9:18 PM, Ozik, Jonathan wrote:
>>> Sounds great. Thanks!
>>>> On Nov 3, 2014, at 9:10 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>> Vesta was down for maintenance today- I'll get back to you tomorrow.
>>>> On 11/3/2014 6:12 PM, Ozik, Jonathan wrote:
>>>>> Hi all,
>>>>> I’m following up on the public stc and turbine builds on Vesta. Any luck on those?
>>>>> Thanks as always,
>>>>> Jonathan
>>>>>> On Oct 31, 2014, at 2:06 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>>> That would be great. Please let me know if I can help out with anything.
>>>>>> Jonathan
>>>>>>> On Oct 31, 2014, at 2:04 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>>> I can set you up with one.
>>>>>>> On 10/31/2014 01:52 PM, Ozik, Jonathan wrote:
>>>>>>>> Hello all,
>>>>>>>> I’m trying to run some simple scripts on Vesta and was wondering if there are more recent publicly available stc and turbine builds than the ones under /home/wozniak/Public ?
>>>>>>>> Jonathan
>>>>>>>> _______________________________________________
>>>>>>>> ExM-user mailing list
>>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>> Justin M Wozniak
>>>> Justin M Wozniak
>> Justin M Wozniak
Justin M Wozniak
More information about the ExM-user
