[ExM Users] Running on Vesta
Ozik, Jonathan jozik at anl.gov
Mon Nov 3 23:21:34 CST 2014
Thanks Justin.
Is there an easy way to transfer input files to the working directory that’s used? Is it just a matter of specifying a working directory for execution or is there a better way?
Jonathan
> On Nov 3, 2014, at 9:37 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> Ok, it's ready to try.  Since this is based on trunk, you can use the latest command-line interface:
> $ PATH=/home/wozniak/Public/sfw/stc/bin:$PATH
> $ export MODE=BGQ QUEUE=default PROJECT=ExM
> $ swift-t -m cobalt ~/p.swift
> On 11/3/2014 9:18 PM, Ozik, Jonathan wrote:
>> Sounds great. Thanks!
>>> On Nov 3, 2014, at 9:10 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>> Vesta was down for maintenance today- I'll get back to you tomorrow.
>>> On 11/3/2014 6:12 PM, Ozik, Jonathan wrote:
>>>> Hi all,
>>>> I’m following up on the public stc and turbine builds on Vesta. Any luck on those?
>>>> Thanks as always,
>>>> Jonathan
>>>>> On Oct 31, 2014, at 2:06 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>> That would be great. Please let me know if I can help out with anything.
>>>>> Jonathan
>>>>>> On Oct 31, 2014, at 2:04 PM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
>>>>>> I can set you up with one.
>>>>>> On 10/31/2014 01:52 PM, Ozik, Jonathan wrote:
>>>>>>> Hello all,
>>>>>>> I’m trying to run some simple scripts on Vesta and was wondering if there are more recent publicly available stc and turbine builds than the ones under /home/wozniak/Public ?
>>>>>>> Jonathan
>>>>>>> _______________________________________________
>>>>>>> ExM-user mailing list
>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>> Justin M Wozniak
>>> Justin M Wozniak
> Justin M Wozniak
More information about the ExM-user mailing list
