[ExM Users] nested foreach and variable scope
Tim Armstrong
tim.g.armstrong at gmail.com
Fri Jun 27 17:12:07 CDT 2014
Yep, I can reproduce this on trunk, I created an issue for it:
https://code.google.com/p/exm-issues/issues/detail?id=716
- Tim
On Fri, Jun 27, 2014 at 5:02 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
> That sounds like a bug. I'll see if I can reproduce.
> - Tim
> On Fri, Jun 27, 2014 at 4:54 PM, Ketan Maheshwari <ketan at mcs.anl.gov>
> wrote:
>> Consider the following two cases:
>> 1.
>> main{
>> file files[] = glob("adir/*.txt");
>> string commands[]=split(read(input_file("./commands.txt")),"\n");
>> foreach afile, i in files{
>> printf("%s", filename(afile));
>> foreach command, j in commands{
>> printf("%s", command);
>> 2.
>> main{
>> Case 1 works while 2 shows error at runtime as follows:
>> can't read "u:afile": no such variable
>> while executing
>> "turbine::file_read_refcount_incr ${u:afile} [ expr { ${tcltmp:iters} - 1
>> Any clue?
>> Thanks,
>> Ketan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140627/b1544434/attachment-0001.html>
More information about the ExM-user
