[ExM Users] turbine-aprun-run doesn't create directory
    Ketan Maheshwari
    ketan at mcs.anl.gov
    Mon Jun 30 13:42:29 CDT 2014
With the following line:
file output<sprintf("results/cmdout%i%i.txt", i,j)> = runcommand(command+"
"+filename(afile));
I expect turbine to create a directory "results", in the jobdir  in the
case of turbine-aprun-run.zsh, but it seems this is not created. Is this
expected behavior?
The full script is:
import files;
import io;
import string;
import python;
app (file out) runcommand (string instr){
   "/bin/sh" "-c" instr @stdout=out;
main{
    file files[] = glob("adir/*.txt");
    string commands[]=["head","tail","stat"];
    foreach afile, i in files{
        foreach command, j in commands{
runcommand(command+" "+filename(afile));
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140630/deb08ab0/attachment.html>
More information about the ExM-user
