[ExM Users] nested foreach and variable scope
Tim Armstrong
tim.g.armstrong at gmail.com
Fri Jun 27 17:02:22 CDT 2014
That sounds like a bug. I'll see if I can reproduce.
- Tim
On Fri, Jun 27, 2014 at 4:54 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> Consider the following two cases:
> 1.
> main{
> file files[] = glob("adir/*.txt");
> string commands[]=split(read(input_file("./commands.txt")),"\n");
> foreach afile, i in files{
> printf("%s", filename(afile));
> foreach command, j in commands{
> printf("%s", command);
> 2.
> main{
> Case 1 works while 2 shows error at runtime as follows:
> can't read "u:afile": no such variable
> while executing
> "turbine::file_read_refcount_incr ${u:afile} [ expr { ${tcltmp:iters} - 1
> Any clue?
> Thanks,
> Ketan
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140627/e75940a5/attachment.html>
More information about the ExM-user
