[ExM Users] debugging suggestions for non-static main-wrap segfault
Tim Armstrong
tim.g.armstrong at gmail.com
Tue Jul 29 10:05:47 CDT 2014
I don't have any particular insight into the cause of the segfault, I can
help with the debugger though.
You need to point gdb at the tclsh that is being used by turbine (which is
just a shell script). You can locate the correct tclsh by looking at TCLSH
in scripts/turbine-config.sh in the turbine install directory.
- TIm
On Tue, Jul 29, 2014 at 10:00 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
wrote:
> Hi,
> Trying to main-wrap DOCK 6.6 application for ATPESC, I get the build right
> (seems) but things fail at runtime giving segfault:
> $ turbine -n 4 user-code.tcl
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = EXIT CODE: 139
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault
> (signal 11)
> This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
> This is on MCS machine. Any suggestion to debug this? I tried gdb but it
> gives:
> "/nfs2/ketan/exm-install/turbine/bin/turbine": not in executable format:
> File format not recognized
> With strace, I see some signs of missing files but not sure if that is the
> cause of segfault. Attached is the strace output of:
> strace -o strace.out turbine -n 4 user-code.tcl
> The code has some MPI and pthread elements but does not use them as far as
> I understand.
> Thanks for any suggestions.
> Ketan
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140729/926f9d84/attachment-0001.html>
More information about the ExM-user
