[ExM Users] debugging suggestions for non-static main-wrap segfault
Ketan Maheshwari
ketan at mcs.anl.gov
Tue Jul 29 10:00:40 CDT 2014
Trying to main-wrap DOCK 6.6 application for ATPESC, I get the build right
(seems) but things fail at runtime giving segfault:
$ turbine -n 4 user-code.tcl
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 139
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault
(signal 11)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
This is on MCS machine. Any suggestion to debug this? I tried gdb but it
gives:
"/nfs2/ketan/exm-install/turbine/bin/turbine": not in executable format:
File format not recognized
With strace, I see some signs of missing files but not sure if that is the
cause of segfault. Attached is the strace output of:
strace -o strace.out turbine -n 4 user-code.tcl
The code has some MPI and pthread elements but does not use them as far as
I understand.
Thanks for any suggestions.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140729/9f5b8a0a/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140729/9f5b8a0a/attachment.obj>
More information about the ExM-user
