[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Fan Zhang
zhangfan at cac.rutgers.edu
Thu Jun 13 16:46:25 CDT 2013
Please see attached file. Also, I tried to print the string variable
'inputFile' right before line
exm.stc.ui.STCompiler.parseFile(STCompiler.java:130).
My command is "stc hello.swift hello.tcl", the 'inputFile' value is
"/var/folders/_8/qky8fqpn6_578_gmy5j1qxr00000gn/T/stc-preproc148496063582809381.swift",
which does not exist (at least after the command failed). Thanks a lot.
Fan
On Thu, Jun 13, 2013 at 5:01 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> Can you send hello.swift?
> On 06/13/2013 03:15 PM, Fan Zhang wrote:
> Hi Justin,
> Thanks for your testing and reply. I just made a clean reinstall and
> can successfully build turbine and stc now. I have been only using the
> exm-setup.zsh to build it, probably there are some object files were not
> cleared after I installed the mpich 3.0.4.
> However, when I was running stc to compile a simple swift script, it
> gave the error below. The command I used is "stc hello.swift hello.tcl".
> STC INTERNAL ERROR
> Please report this
> java.lang.NullPointerException
> at org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:179)
> at org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:189)
> at exm.stc.frontend.SwiftModule.parse(SwiftModule.java:46)
> at exm.stc.ui.STCompiler.parseFile(STCompiler.java:130)
> at exm.stc.ui.STCompiler.compile(STCompiler.java:63)
> at exm.stc.ui.Main.main(Main.java:93)
> Thanks for your time.
> Regards,
> Fan
> On Thu, Jun 13, 2013 at 11:39 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>> I just tested this on darwin12 with SWIG 2.0.9 and could not reproduce
>> it.
>> Can you send the generated SwiftBlob_wrap.c file and the output of make
>> clean ; make V=1
>> On 06/12/2013 01:30 PM, Fan Zhang wrote:
>> Hi Justin,
>> I go the same errors after updating SWIG to 2.0.9.
>> SWIG Version 2.0.9
>> Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
>> Regards,
>> Fan
>> On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>>> Hi
>>> I think the issue may be that we have not tested with SWIG prior to
>>> 2.0.4. Can you update SWIG to 2.0.4 or newer and try again? If this is
>>> the issue, I will update the installation guides and checks.
>>> Thanks
>>> Justin
>>> On 06/12/2013 10:45 AM, Fan Zhang wrote:
>>> Hi All,
>>> I'm trying to install Swift/T 0.3.0 on my macbook pro.
>>> When the setup script is building turbine, it gave the following
>>> errors:
>>> CC src/tcl/blob/SwiftBlob_wrap.o
>>> src/tcl/blob/SwiftBlob_wrap.c:126: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘*’ token
>>> src/tcl/blob/SwiftBlob_wrap.c:127: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘swig_module’
>>> In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
>>> src/tcl/blob/blob.h:54: error: expected ‘)’ before ‘bytes’
>>> src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c: In function ‘swig_delete_turbine_blob’:
>>> src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit declaration of
>>> function ‘free’
>>> src/tcl/blob/SwiftBlob_wrap.c: At top level:
>>> src/tcl/blob/SwiftBlob_wrap.c:217: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘swig_turbine_blob_methods’
>>> src/tcl/blob/SwiftBlob_wrap.c:220: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘swig_turbine_blob_attributes’
>>> src/tcl/blob/SwiftBlob_wrap.c:225: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> src/tcl/blob/SwiftBlob_wrap.c:227: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘_wrap_class_turbine_blob’
>>> src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ‘)’ before
>>> ‘clientData’
>>> src/tcl/blob/SwiftBlob_wrap.c:449: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘swig_commands’
>>> src/tcl/blob/SwiftBlob_wrap.c:478: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘swig_variables’
>>> src/tcl/blob/SwiftBlob_wrap.c:482: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘swig_constants’
>>> src/tcl/blob/SwiftBlob_wrap.c:488: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘_swigt__p_turbine_blob’
>>> src/tcl/blob/SwiftBlob_wrap.c:490: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> src/tcl/blob/SwiftBlob_wrap.c:494: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> or ‘__attribute__’ before ‘_swigc__p_turbine_blob’
>>> src/tcl/blob/SwiftBlob_wrap.c:496: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>>> src/tcl/blob/SwiftBlob_wrap.c:506: error: expected identifier or ‘(’
>>> before ‘return’
>>> src/tcl/blob/SwiftBlob_wrap.c:507: error: expected identifier or ‘(’
>>> before ‘}’ token
>>> src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ‘)’ before ‘*’ token
>>> make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
>>> exm-setup.zsh: turbine: make FAILED
>>> Below is the configure command for turbine:
>>> ./configure --config-cache
>>> --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
>>> --with-tcl=/usr/ --with-mpi=/opt/local
>>> --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils--with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
>>> I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed. What could be the
>>> problems? Thanks a lot.
>>> Regards,
>>> Fan
>>> The Applied Software Systems Laboratory (TASSL)
>>> Department of Electrical and Computer Engineering
>>> Rutgers, The State University of New Jersey
>>> Email: zhangfan at cac.rutgers.edu
>>> Personal web: http://sites.google.com/site/zhangfan198538
>>> Lab web: http://nsfcac.rutgers.edu/TASSL/
>>> _______________________________________________
>>> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>> Justin M Wozniak
>> Justin M Wozniak
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/847b02dc/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/847b02dc/attachment-0001.obj>
More information about the ExM-user
