[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Justin M Wozniak
wozniak at mcs.anl.gov
Thu Jun 13 16:54:39 CDT 2013
Ah- there is some bug in our CPP preprocessing on the Mac.
You can disable preprocessing by running:
stc -p hello.swift hello.tcl
On 06/13/2013 04:46 PM, Fan Zhang wrote:
> Please see attached file. Also, I tried to print the string variable
> 'inputFile' right before line
> exm.stc.ui.STCompiler.parseFile(STCompiler.java:130). My command is
> "stc hello.swift hello.tcl", the 'inputFile' value is
> "/var/folders/_8/qky8fqpn6_578_gmy5j1qxr00000gn/T/stc-preproc148496063582809381.swift",
> which does not exist (at least after the command failed). Thanks a lot.
> Regards,
> Fan
> On Thu, Jun 13, 2013 at 5:01 PM, Justin M Wozniak <wozniak at mcs.anl.gov
> <mailto:wozniak at mcs.anl.gov>> wrote:
> Can you send hello.swift?
> On 06/13/2013 03:15 PM, Fan Zhang wrote:
>> Hi Justin,
>> Thanks for your testing and reply. I just made a clean
>> reinstall and can successfully build turbine and stc now. I have
>> been only using the exm-setup.zsh to build it, probably there are
>> some object files were not cleared after I installed the mpich 3.0.4.
>> However, when I was running stc to compile a simple swift
>> script, it gave the error below. The command I used is "stc
>> hello.swift hello.tcl".
>> STC INTERNAL ERROR
>> Please report this
>> java.lang.NullPointerException
>> at
>> org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:179)
>> at
>> org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:189)
>> at exm.stc.frontend.SwiftModule.parse(SwiftModule.java:46)
>> at exm.stc.ui.STCompiler.parseFile(STCompiler.java:130)
>> at exm.stc.ui.STCompiler.compile(STCompiler.java:63)
>> at exm.stc.ui.Main.main(Main.java:93)
>> Thanks for your time.
>> Regards,
>> Fan
>> On Thu, Jun 13, 2013 at 11:39 AM, Justin M Wozniak
>> <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
>> I just tested this on darwin12 with SWIG 2.0.9 and could not
>> reproduce it.
>> Can you send the generated SwiftBlob_wrap.c file and the
>> output of make clean ; make V=1
>> On 06/12/2013 01:30 PM, Fan Zhang wrote:
>>> Hi Justin,
>>> I go the same errors after updating SWIG to 2.0.9.
>>> SWIG Version 2.0.9
>>> Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
>>> Regards,
>>> Fan
>>> On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak
>>> Hi
>>> I think the issue may be that we have not tested with
>>> SWIG prior to 2.0.4. Can you update SWIG to 2.0.4 or
>>> newer and try again? If this is the issue, I will
>>> update the installation guides and checks.
>>> Thanks
>>> Justin
>>> On 06/12/2013 10:45 AM, Fan Zhang wrote:
>>>> Hi All,
>>>> I'm trying to install Swift/T 0.3.0 on my macbook pro.
>>>> When the setup script is building turbine, it gave the
>>>> following errors:
>>>> CCsrc/tcl/blob/SwiftBlob_wrap.o
>>>> src/tcl/blob/SwiftBlob_wrap.c:126: error: expected ‘=’,
>>>> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
>>>> src/tcl/blob/SwiftBlob_wrap.c:127: error: expected ‘=’,
>>>> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_module’
>>>> In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
>>>> src/tcl/blob/blob.h:54: error: expected ‘)’ before ‘bytes’
>>>> src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c: In function
>>>> ‘swig_delete_turbine_blob’:
>>>> src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit
>>>> declaration of function ‘free’
>>>> src/tcl/blob/SwiftBlob_wrap.c: At top level:
>>>> src/tcl/blob/SwiftBlob_wrap.c:217: error: expected ‘=’,
>>>> ‘swig_turbine_blob_methods’
>>>> src/tcl/blob/SwiftBlob_wrap.c:220: error: expected ‘=’,
>>>> ‘swig_turbine_blob_attributes’
>>>> src/tcl/blob/SwiftBlob_wrap.c:225: error: expected ‘=’,
>>>> src/tcl/blob/SwiftBlob_wrap.c:227: error: expected ‘=’,
>>>> ‘_wrap_class_turbine_blob’
>>>> src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ‘)’
>>>> before ‘clientData’
>>>> src/tcl/blob/SwiftBlob_wrap.c:449: error: expected ‘=’,
>>>> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_commands’
>>>> src/tcl/blob/SwiftBlob_wrap.c:478: error: expected ‘=’,
>>>> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_variables’
>>>> src/tcl/blob/SwiftBlob_wrap.c:482: error: expected ‘=’,
>>>> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_constants’
>>>> src/tcl/blob/SwiftBlob_wrap.c:488: error: expected ‘=’,
>>>> ‘_swigt__p_turbine_blob’
>>>> src/tcl/blob/SwiftBlob_wrap.c:490: error: expected ‘=’,
>>>> src/tcl/blob/SwiftBlob_wrap.c:494: error: expected ‘=’,
>>>> ‘_swigc__p_turbine_blob’
>>>> src/tcl/blob/SwiftBlob_wrap.c:496: error: expected ‘=’,
>>>> src/tcl/blob/SwiftBlob_wrap.c:506: error: expected
>>>> identifier or ‘(’ before ‘return’
>>>> src/tcl/blob/SwiftBlob_wrap.c:507: error: expected
>>>> identifier or ‘(’ before ‘}’ token
>>>> src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ‘)’
>>>> before ‘*’ token
>>>> make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
>>>> exm-setup.zsh: turbine: make FAILED
>>>> Below is the configure command for turbine:
>>>> ./configure --config-cache
>>>> --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
>>>> --with-tcl=/usr/ --with-mpi=/opt/local
>>>> --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils--with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
>>>> I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed.
>>>> What could be the problems? Thanks a lot.
>>>> Regards,
>>>> Fan
>>>> The Applied Software Systems Laboratory (TASSL)
>>>> Department of Electrical and Computer Engineering
>>>> Rutgers, The State University of New Jersey
>>>> Email: zhangfan at cac.rutgers.edu
>>>> <mailto:zhangfan at cac.rutgers.edu>
>>>> Personal web: http://sites.google.com/site/zhangfan198538
>>>> Lab web: http://nsfcac.rutgers.edu/TASSL/
>>>> _______________________________________________
>>>> ExM-user mailing list
>>>> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>> Justin M Wozniak
>> Justin M Wozniak
>> Email: zhangfan at cac.rutgers.edu <mailto:zhangfan at cac.rutgers.edu>
> Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/1565534a/attachment-0001.html>
More information about the ExM-user
