[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Justin M Wozniak wozniak at mcs.anl.gov
Thu Jun 13 16:01:34 CDT 2013
Can you send hello.swift?
On 06/13/2013 03:15 PM, Fan Zhang wrote:
> Hi Justin,
>     Thanks for your testing and reply. I just made a clean reinstall
> and can successfully build turbine and stc now. I have been only using
> the exm-setup.zsh to build it, probably there are some object files
> were not cleared after I installed the mpich 3.0.4.
>     However, when I was running stc to compile a simple swift script,
> it gave the error below. The command I used is "stc hello.swift
> hello.tcl".
> STC INTERNAL ERROR
> Please report this
> java.lang.NullPointerException
> at org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:179)
> at org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:189)
> at exm.stc.frontend.SwiftModule.parse(SwiftModule.java:46)
> at exm.stc.ui.STCompiler.parseFile(STCompiler.java:130)
> at exm.stc.ui.STCompiler.compile(STCompiler.java:63)
> at exm.stc.ui.Main.main(Main.java:93)
>     Thanks for your time.
> Regards,
> Fan
> On Thu, Jun 13, 2013 at 11:39 AM, Justin M Wozniak
> <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
>     I just tested this on darwin12 with SWIG 2.0.9 and could not
>     reproduce it.
>     Can you send the generated SwiftBlob_wrap.c file and the output of
>     make clean ; make V=1
>     On 06/12/2013 01:30 PM, Fan Zhang wrote:
>>     Hi Justin,
>>         I go the same errors after updating SWIG to 2.0.9.
>>     SWIG Version 2.0.9
>>     Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
>>     Regards,
>>     Fan
>>     On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak
>>         Hi
>>            I think the issue may be that we have not tested with SWIG
>>         prior to 2.0.4.  Can you update SWIG to 2.0.4 or newer and
>>         try again?  If this is the issue, I will update the
>>         installation guides and checks.
>>             Thanks
>>             Justin
>>         On 06/12/2013 10:45 AM, Fan Zhang wrote:
>>>         Hi All,
>>>         I'm trying to install Swift/T 0.3.0 on my macbook pro.
>>>         When the setup script is building turbine, it gave the
>>>         following errors:
>>>           CCsrc/tcl/blob/SwiftBlob_wrap.o
>>>         src/tcl/blob/SwiftBlob_wrap.c:126: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
>>>         src/tcl/blob/SwiftBlob_wrap.c:127: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_module’
>>>         In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
>>>         src/tcl/blob/blob.h:54: error: expected ‘)’ before ‘bytes’
>>>         src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c: In function
>>>         ‘swig_delete_turbine_blob’:
>>>         src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit
>>>         declaration of function ‘free’
>>>         src/tcl/blob/SwiftBlob_wrap.c: At top level:
>>>         src/tcl/blob/SwiftBlob_wrap.c:217: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_turbine_blob_methods’
>>>         src/tcl/blob/SwiftBlob_wrap.c:220: error: expected ‘=’, ‘,’,
>>>         ‘swig_turbine_blob_attributes’
>>>         src/tcl/blob/SwiftBlob_wrap.c:225: error: expected ‘=’, ‘,’,
>>>         src/tcl/blob/SwiftBlob_wrap.c:227: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘_wrap_class_turbine_blob’
>>>         src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ‘)’
>>>         before ‘clientData’
>>>         src/tcl/blob/SwiftBlob_wrap.c:449: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_commands’
>>>         src/tcl/blob/SwiftBlob_wrap.c:478: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_variables’
>>>         src/tcl/blob/SwiftBlob_wrap.c:482: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘swig_constants’
>>>         src/tcl/blob/SwiftBlob_wrap.c:488: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘_swigt__p_turbine_blob’
>>>         src/tcl/blob/SwiftBlob_wrap.c:490: error: expected ‘=’, ‘,’,
>>>         src/tcl/blob/SwiftBlob_wrap.c:494: error: expected ‘=’, ‘,’,
>>>         ‘;’, ‘asm’ or ‘__attribute__’ before ‘_swigc__p_turbine_blob’
>>>         src/tcl/blob/SwiftBlob_wrap.c:496: error: expected ‘=’, ‘,’,
>>>         src/tcl/blob/SwiftBlob_wrap.c:506: error: expected
>>>         identifier or ‘(’ before ‘return’
>>>         src/tcl/blob/SwiftBlob_wrap.c:507: error: expected
>>>         identifier or ‘(’ before ‘}’ token
>>>         src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ‘)’
>>>         before ‘*’ token
>>>         make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
>>>         exm-setup.zsh: turbine: make FAILED
>>>         Below is the configure command for turbine:
>>>         ./configure --config-cache
>>>         --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
>>>         --with-tcl=/usr/ --with-mpi=/opt/local
>>>         --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils--with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
>>>         I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed. What
>>>         could be the problems? Thanks a lot.
>>>         Regards,
>>>         Fan
>>>         The Applied Software Systems Laboratory (TASSL)
>>>         Department of Electrical and Computer Engineering
>>>         Rutgers, The State University of New Jersey
>>>         Email: zhangfan at cac.rutgers.edu
>>>         <mailto:zhangfan at cac.rutgers.edu>
>>>         Personal web: http://sites.google.com/site/zhangfan198538
>>>         Lab web: http://nsfcac.rutgers.edu/TASSL/
>>>         _______________________________________________
>>>         ExM-user mailing list
>>>         ExM-user at lists.mcs.anl.gov  <mailto:ExM-user at lists.mcs.anl.gov>
>>>         https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>         Justin M Wozniak
>>     Email: zhangfan at cac.rutgers.edu <mailto:zhangfan at cac.rutgers.edu>
>     Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/cce76538/attachment-0001.html>
More information about the ExM-user mailing list
