[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Fan Zhang zhangfan at cac.rutgers.edu
Thu Jun 13 15:15:53 CDT 2013
Hi Justin,
    Thanks for your testing and reply. I just made a clean reinstall and
can successfully build turbine and stc now. I have been only using the
exm-setup.zsh to build it, probably there are some object files were not
cleared after I installed the mpich 3.0.4.
    However, when I was running stc to compile a simple swift script, it
gave the error below. The command I used is "stc hello.swift hello.tcl".
STC INTERNAL ERROR
Please report this
java.lang.NullPointerException
at org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:179)
at org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:189)
at exm.stc.frontend.SwiftModule.parse(SwiftModule.java:46)
at exm.stc.ui.STCompiler.parseFile(STCompiler.java:130)
at exm.stc.ui.STCompiler.compile(STCompiler.java:63)
at exm.stc.ui.Main.main(Main.java:93)
    Thanks for your time.
Fan
On Thu, Jun 13, 2013 at 11:39 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> I just tested this on darwin12 with SWIG 2.0.9 and could not reproduce
> it.
> Can you send the generated SwiftBlob_wrap.c file and the output of make
> clean ; make V=1
> On 06/12/2013 01:30 PM, Fan Zhang wrote:
> Hi Justin,
>      I go the same errors after updating SWIG to 2.0.9.
>  SWIG Version 2.0.9
>  Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
>  Regards,
>  Fan
> On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>>  Hi
>>    I think the issue may be that we have not tested with SWIG prior to
>> 2.0.4.  Can you update SWIG to 2.0.4 or newer and try again?  If this is
>> the issue, I will update the installation guides and checks.
>>     Thanks
>>     Justin
>> On 06/12/2013 10:45 AM, Fan Zhang wrote:
>>   Hi All,
>>  I'm trying to install Swift/T 0.3.0 on my macbook pro.
>>  When the setup script is building turbine, it gave the following errors:
>>    CC src/tcl/blob/SwiftBlob_wrap.o
>> src/tcl/blob/SwiftBlob_wrap.c:126: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘*’ token
>> src/tcl/blob/SwiftBlob_wrap.c:127: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘swig_module’
>> In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
>> src/tcl/blob/blob.h:54: error: expected ‘)’ before ‘bytes’
>> src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c: In function ‘swig_delete_turbine_blob’:
>> src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit declaration of
>> function ‘free’
>> src/tcl/blob/SwiftBlob_wrap.c: At top level:
>> src/tcl/blob/SwiftBlob_wrap.c:217: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘swig_turbine_blob_methods’
>> src/tcl/blob/SwiftBlob_wrap.c:220: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘swig_turbine_blob_attributes’
>> src/tcl/blob/SwiftBlob_wrap.c:225: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> src/tcl/blob/SwiftBlob_wrap.c:227: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘_wrap_class_turbine_blob’
>> src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ‘)’ before ‘clientData’
>> src/tcl/blob/SwiftBlob_wrap.c:449: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘swig_commands’
>> src/tcl/blob/SwiftBlob_wrap.c:478: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘swig_variables’
>> src/tcl/blob/SwiftBlob_wrap.c:482: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘swig_constants’
>> src/tcl/blob/SwiftBlob_wrap.c:488: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘_swigt__p_turbine_blob’
>> src/tcl/blob/SwiftBlob_wrap.c:490: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> src/tcl/blob/SwiftBlob_wrap.c:494: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> or ‘__attribute__’ before ‘_swigc__p_turbine_blob’
>> src/tcl/blob/SwiftBlob_wrap.c:496: error: expected ‘=’, ‘,’, ‘;’, ‘asm’
>> src/tcl/blob/SwiftBlob_wrap.c:506: error: expected identifier or ‘(’
>> before ‘return’
>> src/tcl/blob/SwiftBlob_wrap.c:507: error: expected identifier or ‘(’
>> before ‘}’ token
>> src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ‘)’ before ‘*’ token
>> make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
>> exm-setup.zsh: turbine: make FAILED
>>  Below is the configure command for turbine:
>> ./configure --config-cache
>> --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
>> --with-tcl=/usr/ --with-mpi=/opt/local
>> --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils--with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
>>  I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed. What could be the
>> problems? Thanks a lot.
>> Regards,
>>  Fan
>> The Applied Software Systems Laboratory (TASSL)
>> Department of Electrical and Computer Engineering
>> Rutgers, The State University of New Jersey
>> Email: zhangfan at cac.rutgers.edu
>> Personal web: http://sites.google.com/site/zhangfan198538
>> Lab web: http://nsfcac.rutgers.edu/TASSL/
>>  _______________________________________________
>> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
>> Justin M Wozniak
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/f59b2e53/attachment.html>
More information about the ExM-user mailing list
