[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Justin M Wozniak wozniak at mcs.anl.gov
Thu Jun 13 10:39:59 CDT 2013
I just tested this on darwin12 with SWIG 2.0.9 and could not reproduce it.
Can you send the generated SwiftBlob_wrap.c file and the output of make
clean ; make V=1
On 06/12/2013 01:30 PM, Fan Zhang wrote:
> Hi Justin,
>     I go the same errors after updating SWIG to 2.0.9.
> SWIG Version 2.0.9
> Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
> Regards,
> Fan
> On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak <wozniak at mcs.anl.gov
> <mailto:wozniak at mcs.anl.gov>> wrote:
>     Hi
>        I think the issue may be that we have not tested with SWIG
>     prior to 2.0.4.  Can you update SWIG to 2.0.4 or newer and try
>     again?  If this is the issue, I will update the installation
>     guides and checks.
>         Thanks
>         Justin
>     On 06/12/2013 10:45 AM, Fan Zhang wrote:
>>     Hi All,
>>     I'm trying to install Swift/T 0.3.0 on my macbook pro.
>>     When the setup script is building turbine, it gave the following
>>     errors:
>>       CCsrc/tcl/blob/SwiftBlob_wrap.o
>>     src/tcl/blob/SwiftBlob_wrap.c:126: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘*’ token
>>     src/tcl/blob/SwiftBlob_wrap.c:127: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘swig_module’
>>     In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
>>     src/tcl/blob/blob.h:54: error: expected ‘)’ before ‘bytes’
>>     src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c: In function
>>     ‘swig_delete_turbine_blob’:
>>     src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit declaration
>>     of function ‘free’
>>     src/tcl/blob/SwiftBlob_wrap.c: At top level:
>>     src/tcl/blob/SwiftBlob_wrap.c:217: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘swig_turbine_blob_methods’
>>     src/tcl/blob/SwiftBlob_wrap.c:220: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘swig_turbine_blob_attributes’
>>     src/tcl/blob/SwiftBlob_wrap.c:225: error: expected ‘=’, ‘,’, ‘;’,
>>     src/tcl/blob/SwiftBlob_wrap.c:227: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘_wrap_class_turbine_blob’
>>     src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ‘)’ before
>>     ‘clientData’
>>     src/tcl/blob/SwiftBlob_wrap.c:449: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘swig_commands’
>>     src/tcl/blob/SwiftBlob_wrap.c:478: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘swig_variables’
>>     src/tcl/blob/SwiftBlob_wrap.c:482: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘swig_constants’
>>     src/tcl/blob/SwiftBlob_wrap.c:488: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘_swigt__p_turbine_blob’
>>     src/tcl/blob/SwiftBlob_wrap.c:490: error: expected ‘=’, ‘,’, ‘;’,
>>     src/tcl/blob/SwiftBlob_wrap.c:494: error: expected ‘=’, ‘,’, ‘;’,
>>     ‘asm’ or ‘__attribute__’ before ‘_swigc__p_turbine_blob’
>>     src/tcl/blob/SwiftBlob_wrap.c:496: error: expected ‘=’, ‘,’, ‘;’,
>>     src/tcl/blob/SwiftBlob_wrap.c:506: error: expected identifier or
>>     ‘(’ before ‘return’
>>     src/tcl/blob/SwiftBlob_wrap.c:507: error: expected identifier or
>>     ‘(’ before ‘}’ token
>>     src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ‘)’ before ‘*’
>>     token
>>     make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
>>     exm-setup.zsh: turbine: make FAILED
>>     Below is the configure command for turbine:
>>     ./configure --config-cache
>>     --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
>>     --with-tcl=/usr/ --with-mpi=/opt/local
>>     --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils--with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
>>     I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed. What could be
>>     the problems? Thanks a lot.
>>     Regards,
>>     Fan
>>     The Applied Software Systems Laboratory (TASSL)
>>     Department of Electrical and Computer Engineering
>>     Rutgers, The State University of New Jersey
>>     Email: zhangfan at cac.rutgers.edu <mailto:zhangfan at cac.rutgers.edu>
>>     Personal web: http://sites.google.com/site/zhangfan198538
>>     Lab web: http://nsfcac.rutgers.edu/TASSL/
>>     _______________________________________________
>>     ExM-user mailing list
>>     ExM-user at lists.mcs.anl.gov  <mailto:ExM-user at lists.mcs.anl.gov>
>>     https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>     Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/12bb8c0f/attachment-0001.html>
More information about the ExM-user mailing list
