[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Fan Zhang
zhangfan at cac.rutgers.edu
Wed Jun 12 13:30:01 CDT 2013
Hi Justin,
I go the same errors after updating SWIG to 2.0.9.
SWIG Version 2.0.9
Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
Fan
On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> Hi
> I think the issue may be that we have not tested with SWIG prior to
> 2.0.4. Can you update SWIG to 2.0.4 or newer and try again? If this is
> the issue, I will update the installation guides and checks.
> Thanks
> Justin
> On 06/12/2013 10:45 AM, Fan Zhang wrote:
> Hi All,
> I'm trying to install Swift/T 0.3.0 on my macbook pro.
> When the setup script is building turbine, it gave the following errors:
> CC src/tcl/blob/SwiftBlob_wrap.o
> src/tcl/blob/SwiftBlob_wrap.c:126: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘*’ token
> src/tcl/blob/SwiftBlob_wrap.c:127: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘swig_module’
> In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
> src/tcl/blob/blob.h:54: error: expected ‘)’ before ‘bytes’
> src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c: In function ‘swig_delete_turbine_blob’:
> src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit declaration of
> function ‘free’
> src/tcl/blob/SwiftBlob_wrap.c: At top level:
> src/tcl/blob/SwiftBlob_wrap.c:217: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘swig_turbine_blob_methods’
> src/tcl/blob/SwiftBlob_wrap.c:220: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘swig_turbine_blob_attributes’
> src/tcl/blob/SwiftBlob_wrap.c:225: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> src/tcl/blob/SwiftBlob_wrap.c:227: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘_wrap_class_turbine_blob’
> src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ‘)’ before ‘clientData’
> src/tcl/blob/SwiftBlob_wrap.c:449: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘swig_commands’
> src/tcl/blob/SwiftBlob_wrap.c:478: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘swig_variables’
> src/tcl/blob/SwiftBlob_wrap.c:482: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘swig_constants’
> src/tcl/blob/SwiftBlob_wrap.c:488: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘_swigt__p_turbine_blob’
> src/tcl/blob/SwiftBlob_wrap.c:490: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> src/tcl/blob/SwiftBlob_wrap.c:494: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> ‘__attribute__’ before ‘_swigc__p_turbine_blob’
> src/tcl/blob/SwiftBlob_wrap.c:496: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
> src/tcl/blob/SwiftBlob_wrap.c:506: error: expected identifier or ‘(’
> before ‘return’
> src/tcl/blob/SwiftBlob_wrap.c:507: error: expected identifier or ‘(’
> before ‘}’ token
> src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ‘)’ before ‘*’ token
> make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
> exm-setup.zsh: turbine: make FAILED
> Below is the configure command for turbine:
> ./configure --config-cache
> --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
> --with-tcl=/usr/ --with-mpi=/opt/local
> --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils
> --with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
> I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed. What could be the
> problems? Thanks a lot.
> Regards,
> Fan
> The Applied Software Systems Laboratory (TASSL)
> Department of Electrical and Computer Engineering
> Rutgers, The State University of New Jersey
> Email: zhangfan at cac.rutgers.edu
> Personal web: http://sites.google.com/site/zhangfan198538
> Lab web: http://nsfcac.rutgers.edu/TASSL/
> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130612/4a57dd02/attachment.html>
More information about the ExM-user
