[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Justin M Wozniak
wozniak at mcs.anl.gov
Wed Jun 12 13:07:45 CDT 2013
Hi
I think the issue may be that we have not tested with SWIG prior to
2.0.4. Can you update SWIG to 2.0.4 or newer and try again? If this is
the issue, I will update the installation guides and checks.
Thanks
Justin
On 06/12/2013 10:45 AM, Fan Zhang wrote:
> Hi All,
> I'm trying to install Swift/T 0.3.0 on my macbook pro.
> When the setup script is building turbine, it gave the following errors:
> CCsrc/tcl/blob/SwiftBlob_wrap.o
> src/tcl/blob/SwiftBlob_wrap.c:126: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before '*' token
> src/tcl/blob/SwiftBlob_wrap.c:127: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before 'swig_module'
> In file included from src/tcl/blob/SwiftBlob_wrap.c:138:
> src/tcl/blob/blob.h:54: error: expected ')' before 'bytes'
> src/tcl/blob/SwiftBlob_wrap.c:144: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:156: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:168: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:180: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:192: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:203: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c: In function 'swig_delete_turbine_blob':
> src/tcl/blob/SwiftBlob_wrap.c:215: warning: implicit declaration of
> function 'free'
> src/tcl/blob/SwiftBlob_wrap.c: At top level:
> src/tcl/blob/SwiftBlob_wrap.c:217: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before 'swig_turbine_blob_methods'
> src/tcl/blob/SwiftBlob_wrap.c:220: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before 'swig_turbine_blob_attributes'
> src/tcl/blob/SwiftBlob_wrap.c:225: error: expected '=', ',', ';',
> src/tcl/blob/SwiftBlob_wrap.c:227: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before '_wrap_class_turbine_blob'
> src/tcl/blob/SwiftBlob_wrap.c:229: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:242: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:255: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:267: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:278: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:289: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:301: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:313: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:325: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:337: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:349: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:361: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:373: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:386: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:399: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:412: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:423: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:436: error: expected ')' before 'clientData'
> src/tcl/blob/SwiftBlob_wrap.c:449: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before 'swig_commands'
> src/tcl/blob/SwiftBlob_wrap.c:478: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before 'swig_variables'
> src/tcl/blob/SwiftBlob_wrap.c:482: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before 'swig_constants'
> src/tcl/blob/SwiftBlob_wrap.c:488: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before '_swigt__p_turbine_blob'
> src/tcl/blob/SwiftBlob_wrap.c:490: error: expected '=', ',', ';',
> src/tcl/blob/SwiftBlob_wrap.c:494: error: expected '=', ',', ';',
> 'asm' or '__attribute__' before '_swigc__p_turbine_blob'
> src/tcl/blob/SwiftBlob_wrap.c:496: error: expected '=', ',', ';',
> src/tcl/blob/SwiftBlob_wrap.c:506: error: expected identifier or '('
> before 'return'
> src/tcl/blob/SwiftBlob_wrap.c:507: error: expected identifier or '('
> before '}' token
> src/tcl/blob/SwiftBlob_wrap.c:508: error: expected ')' before '*' token
> make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
> exm-setup.zsh: turbine: make FAILED
> Below is the configure command for turbine:
> ./configure --config-cache
> --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
> --with-tcl=/usr/ --with-mpi=/opt/local
> --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils
> --with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
> I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5 installed. What could be the
> problems? Thanks a lot.
> Regards,
> Fan
> The Applied Software Systems Laboratory (TASSL)
> Department of Electrical and Computer Engineering
> Rutgers, The State University of New Jersey
> Email: zhangfan at cac.rutgers.edu <mailto:zhangfan at cac.rutgers.edu>
> Personal web: http://sites.google.com/site/zhangfan198538
> Lab web: http://nsfcac.rutgers.edu/TASSL/
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130612/6eca905a/attachment-0001.html>
More information about the ExM-user
