[ExM Users] Installing Swift/T on Raven
Justin M Wozniak
wozniak at mcs.anl.gov
Fri Apr 12 13:44:45 CDT 2013
That configure line points --prefix= ... /c-utils
Also, CFLAGS=-I... should point to an include directory.
Try setting
--with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/46
and let me know what happens. I will try to get on Raven soon to test
this.
On 04/12/2013 12:57 PM, Scott Krieder wrote:
> Hi Justin,
> This is from a tarball from my machine where GeMTC and Swift are
> working, I haven't updated past version 6770. Sorry to bounce around
> with errors but I believe I had an earlier issue with the c-utils/adlb
> install that lead to this turbine issue. When configuring adlb I point
> it at the c-utils install and I get an error regarding the MPI version.
> I'm running:
> ./configure --prefix=/home/users/p01684/Public/c-utils CC=gcc
> --with-c-utils=/home/users/p01684/Public/sfw/c-utils
> CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/46
> LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/46/lib -lmpich"
> I noticed that there are many folders in:
> /opt/cray/mpt/
> Is there a good way to identify which version I should use within
> /opt/cray/mpt? Or am I wrong in assuming that this versioning is what
> is causing the "Could not preprocess maint/mpi_version.cpp" error?
> Thanks,
> Scott
> ==error message==
> checking for cp that supports -u... yes
> using MPE: no
> checking for
> /home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
> using ExM c-utils in /home/users/p01684/Public/sfw/c-utils ...
> checking MPI version... maint/mpi_version.cpp:23:17: error: mpi.h: No
> such file or directory
> configure: error: Could not preprocess maint/mpi_version.cpp
> On Fri, Apr 12, 2013 at 11:28 AM, Justin M Wozniak
> <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
> Hi
> Is this with trunk or with the release package?
> --with-mpi-dir may have been replaced by --with-mpi
> Justin
> On 04/12/2013 11:05 AM, Scott Krieder wrote:
>> Hi All,
>> I'm trying to install Swift/T on Raven. I followed the notes
>> about Cray systems.
>> When I configure turbine with:
>> ./configure --prefix=/home/users/p01684/Public/sfw/turbine
>> --enable-custom
>> --with-mpi-dir=/opt/cray/mpt/default/xt/gemini/mpich2-gnu/46
>> I get a long error about "could not find directory" in reference
>> to mpicc. Is there something I should do in addition to the
>> --with-mpi flag?
>> Thanks,
>> Scott
>> ==Error Message==
>> checking for
>> /ufs/home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
>> which: no mpicc in
>> (/opt/pbs/10.4.0.101257/bin:/opt/cray/atp/1.6.2/bin:/opt/cray/rca/1.0.0-2.0401.38656.2.2.gem/bin:/opt/cray/pmi/4.0.1-1.0000.9421.73.3.gem/bin:/opt/toolworks/totalview.8.11.0-1/bin:/opt/totalview-support/1.1.4/bin:/opt/cray/cce/8.1.4/cray-binutils/x86_64-unknown-linux-gnu/bin:/opt/cray/cce/8.1.4/craylibs/x86-64/bin:/opt/cray/cce/8.1.4/cftn/bin:/opt/cray/cce/8.1.4/CC/bin:/opt/cray/xt-asyncpe/5.20.11/bin:/opt/cray/llm/default/bin:/opt/cray/llm/default/etc:/opt/cray/xpmem/0.1-2.0401.36790.4.3.gem/bin:/opt/cray/dmapp/3.2.1-1.0401.5983.4.5.gem/bin:/opt/cray/ugni/4.0-1.0401.5928.9.5.gem/bin:/opt/cray/udreg/2.3.2-1.0401.5929.3.3.gem/bin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/sbin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/bin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/sbin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/bin:/opt/cray/sdb/1.0-1.0401.38148.4.27.gem/bin:/opt/cray/nodestat/2.2-1.0401.37252.2.1.gem
>> /bin:/opt
>> /modules/3.2.6.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin
>> <http://3.2.6.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin>)
>> ./configure: line 4032: ((: ! : syntax error: operand expected
>> (error token is " ")
>> checking for 0... no
>> configure: error: Could not find directory
>> Scott J. Krieder
>> C: 419-685-0410 <tel:419-685-0410>
>> E: skrieder at iit.edu <mailto:skrieder at iit.edu>
>> http://datasys.cs.iit.edu/~skrieder/
>> <http://datasys.cs.iit.edu/%7Eskrieder/>
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
> Scott J. Krieder
> C: 419-685-0410
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130412/811b79d3/attachment-0001.html>
More information about the ExM-user
