[ExM Users] Installing Swift/T on Raven
Scott Krieder
skrieder at iit.edu
Fri Apr 12 12:57:53 CDT 2013
Hi Justin,
This is from a tarball from my machine where GeMTC and Swift are working, I
haven't updated past version 6770. Sorry to bounce around with errors but I
believe I had an earlier issue with the c-utils/adlb install that lead to
this turbine issue. When configuring adlb I point it at the c-utils install
and I get an error regarding the MPI version.
I'm running:
./configure --prefix=/home/users/p01684/Public/c-utils CC=gcc
--with-c-utils=/home/users/p01684/Public/sfw/c-utils
CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/46
LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/46/lib -lmpich"
I noticed that there are many folders in:
/opt/cray/mpt/
Is there a good way to identify which version I should use within
/opt/cray/mpt? Or am I wrong in assuming that this versioning is what is
causing the "Could not preprocess maint/mpi_version.cpp" error?
Scott
==error message==
checking for cp that supports -u... yes
using MPE: no
checking for /home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
using ExM c-utils in /home/users/p01684/Public/sfw/c-utils ...
checking MPI version... maint/mpi_version.cpp:23:17: error: mpi.h: No such
file or directory
configure: error: Could not preprocess maint/mpi_version.cpp
On Fri, Apr 12, 2013 at 11:28 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> Hi
> Is this with trunk or with the release package?
> --with-mpi-dir may have been replaced by --with-mpi
> Justin
> On 04/12/2013 11:05 AM, Scott Krieder wrote:
> Hi All,
> I'm trying to install Swift/T on Raven. I followed the notes about Cray
> systems.
> When I configure turbine with:
> ./configure --prefix=/home/users/p01684/Public/sfw/turbine --enable-custom
> --with-mpi-dir=/opt/cray/mpt/default/xt/gemini/mpich2-gnu/46
> I get a long error about "could not find directory" in reference to
> mpicc. Is there something I should do in addition to the --with-mpi flag?
> Thanks,
> Scott
> ==Error Message==
> checking for
> /ufs/home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
> which: no mpicc in
> (/opt/pbs/10.4.0.101257/bin:/opt/cray/atp/1.6.2/bin:/opt/cray/rca/1.0.0-2.0401.38656.2.2.gem/bin:/opt/cray/pmi/4.0.1-1.0000.9421.73.3.gem/bin:/opt/toolworks/totalview.8.11.0-1/bin:/opt/totalview-support/1.1.4/bin:/opt/cray/cce/8.1.4/cray-binutils/x86_64-unknown-linux-gnu/bin:/opt/cray/cce/8.1.4/craylibs/x86-64/bin:/opt/cray/cce/8.1.4/cftn/bin:/opt/cray/cce/8.1.4/CC/bin:/opt/cray/xt-asyncpe/5.20.11/bin:/opt/cray/llm/default/bin:/opt/cray/llm/default/etc:/opt/cray/xpmem/0.1-2.0401.36790.4.3.gem/bin:/opt/cray/dmapp/3.2.1-1.0401.5983.4.5.gem/bin:/opt/cray/ugni/4.0-1.0401.5928.9.5.gem/bin:/opt/cray/udreg/2.3.2-1.0401.5929.3.3.gem/bin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/sbin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/bin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/sbin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/bin:/opt/cray/sdb/1.0-1.0401.38148.4.27.gem/bin:/opt/cray/nodestat/2.2-1.0401.37252.2.1.gem
> /bin:/opt /modules/
> 3.2.6.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin
> ./configure: line 4032: ((: ! : syntax error: operand expected (error
> token is " ")
> checking for 0... no
> configure: error: Could not find directory
> Scott J. Krieder
> C: 419-685-0410
> E: skrieder at iit.edu
> http://datasys.cs.iit.edu/~skrieder/
> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
Scott J. Krieder
C: 419-685-0410
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130412/f56e8abe/attachment.html>
More information about the ExM-user
