[Darshan-users] Problem with darshan-job-summary.pl in 3.3.0
Phil Carns carns at mcs.anl.gov
Fri Jun 11 07:35:00 CDT 2021
Hi all,
We followed up in more about this off-list, but just to post here for
the sake of posterity, the fix is in
https://github.com/darshan-hpc/darshan/pull/394 and will be available in
the next Darshan release.
thanks,
-Phil
On 6/7/21 2:05 PM, Phil Carns wrote:
> Hi Jeff,
> I'm guessing it is a bug/corner case in the perl code.  Any chance you
> can share the
> laytonjb_test1_id28730_6-7-43012-2131301613401632697_1.darshan file
> with us so we that we can reproduce?
> thanks,
> -Phil
> On 6/7/21 1:26 PM, Jeffrey Layton wrote:
>> Good afternoon,
>> I just built version 3.3.0 and ran a simple C code that writes some
>> text to stdout, When I try to create a summary pdf file it hangs.
>> I built darhan-3.3.0 using gcc on Ubuntu 20.04. The command I used to
>> create the report is,
>> $ /home/laytonjb/bin/darshan-3.3.0/bin/darshan-job-summary.pl
>> <http://darshan-job-summary.pl>
>> --output jeff --verbose
>> verbose: /tmp/49OfEXSumv
>> Use of uninitialized value $summary{"POSIX_MMAPS"} in numeric lt (<)
>> at /home/laytonjb/bin/darshan-3.3.0/bin/darshan-job-summary.pl
>> <http://darshan-job-summary.pl> line 435.
>> Warning: empty y range [0:0], adjusting to [-1:1]
>> At this point it hangs. I took a peak at the directory in /tmp and
>> found the following:
>> $ ls -s
>> total 320
>>  4 access-hist-eps.gplt   4 file-access-read-sh.dat   8
>> file-access-write.pdf     24 op-counts.eps        8
>> pattern.pdf             0 summary.log             4 title.tex
>>  4 access-table.tex      24 file-access-shared.eps    4
>> file-access-write-sh.dat   4 op-counts-eps.gplt   4
>> posix-access-hist.dat   4 summary.tex             4 variance-table.tex
>>  4 file-access-eps.gplt   8 file-access-shared.pdf    4
>> file-count-table.tex       8 op-counts.pdf       28
>> posix-access-hist.eps   4 time-summary.dat
>>  4 file-access-read.dat   4 file-access-table.tex     4
>> fs-data-table.tex          4 pattern.dat          8
>> posix-access-hist.pdf  24 time-summary.eps
>> 24 file-access-read.eps   4 file-access-write.dat     4
>> job-table.tex             24 pattern.eps          4
>> posix-op-counts.dat     4 time-summary-eps.gplt
>>  8 file-access-read.pdf  24 file-access-write.eps     4
>> latex.output               4 pattern-eps.gplt     4
>> stdio-op-counts.dat     8 time-summary.pdf
>> There are some pdf files and I can read those, but I was hoping for a
>> single pdf file that contained all of the plots like that in the
>> documentation for darshan-utils.
>> Any thoughts on what I'm doing wrong?
>> Thanks!
>> Jeff
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon>
>> 	Virus-free. www.avast.com
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link>
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210611/04d929e6/attachment.html>
More information about the Darshan-users mailing list
