[Darshan-users] Problem with darshan-job-summary.pl in 3.3.0
Phil Carns
carns at mcs.anl.gov
Mon Jun 7 13:05:33 CDT 2021
Hi Jeff,
I'm guessing it is a bug/corner case in the perl code. Any chance you
can share the
laytonjb_test1_id28730_6-7-43012-2131301613401632697_1.darshan file with
us so we that we can reproduce?
thanks,
-Phil
On 6/7/21 1:26 PM, Jeffrey Layton wrote:
> Good afternoon,
> I just built version 3.3.0 and ran a simple C code that writes some
> text to stdout, When I try to create a summary pdf file it hangs.
> I built darhan-3.3.0 using gcc on Ubuntu 20.04. The command I used to
> create the report is,
> $ /home/laytonjb/bin/darshan-3.3.0/bin/darshan-job-summary.pl
> <http://darshan-job-summary.pl>
> --output jeff --verbose
> verbose: /tmp/49OfEXSumv
> Use of uninitialized value $summary{"POSIX_MMAPS"} in numeric lt (<)
> at /home/laytonjb/bin/darshan-3.3.0/bin/darshan-job-summary.pl
> <http://darshan-job-summary.pl> line 435.
> Warning: empty y range [0:0], adjusting to [-1:1]
> At this point it hangs. I took a peak at the directory in /tmp and
> found the following:
> $ ls -s
> total 320
> 4 access-hist-eps.gplt 4 file-access-read-sh.dat 8
> file-access-write.pdf 24 op-counts.eps 8
> pattern.pdf 0 summary.log 4 title.tex
> 4 access-table.tex 24 file-access-shared.eps 4
> file-access-write-sh.dat 4 op-counts-eps.gplt 4
> posix-access-hist.dat 4 summary.tex 4 variance-table.tex
> 4 file-access-eps.gplt 8 file-access-shared.pdf 4
> file-count-table.tex 8 op-counts.pdf 28
> posix-access-hist.eps 4 time-summary.dat
> 4 file-access-read.dat 4 file-access-table.tex 4
> fs-data-table.tex 4 pattern.dat 8
> posix-access-hist.pdf 24 time-summary.eps
> 24 file-access-read.eps 4 file-access-write.dat 4
> job-table.tex 24 pattern.eps 4
> posix-op-counts.dat 4 time-summary-eps.gplt
> 8 file-access-read.pdf 24 file-access-write.eps 4
> latex.output 4 pattern-eps.gplt 4
> stdio-op-counts.dat 8 time-summary.pdf
> There are some pdf files and I can read those, but I was hoping for a
> single pdf file that contained all of the plots like that in the
> documentation for darshan-utils.
> Any thoughts on what I'm doing wrong?
> Thanks!
> Jeff
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon>
> Virus-free. www.avast.com
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link>
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210607/fe6955f0/attachment-0001.html>
More information about the Darshan-users
