[Darshan-users] *****SPAM*****darshan-job-summary.pl (ERROR)
Hassan Asghar
haxxanasghar at gmail.com
Thu Jun 10 02:57:03 CDT 2021
I am generating the analysis report by using the command
*darshan-job-summary.pl <http://darshan-job-summary.pl>
/home/haxxanasghar/darshan-logs/2020/6/10/haxxanas_MADbench2_id50362-50362_6-10-57172-6816275868204404779_1.darshan*
I have installed all the required things like perl, epstopdf, latex, python
and gnuplot:
but again facing the following error:
*Base class package "Pod::Select" is empty. (Perhaps you need to 'use'
the module which defines that package first, or make that module
available in @INC (@INC contains: /usr/local/lib /usr/local/lib64/perl5
/usr/local/share/perl5 /usr/lib64/perl5/vendor_perl
/usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .). at
/usr/local/lib/Pod/LaTeX.pm line 29.BEGIN failed--compilation aborted at
/usr/local/lib/Pod/LaTeX.pm line 29.Compilation failed in require at
/usr/local/lib/TeX/Encode.pm line 10.BEGIN failed--compilation aborted at
/usr/local/lib/TeX/Encode.pm line 10.Compilation failed in require at
/usr/local/bin/darshan-job-summary.pl <http://darshan-job-summary.pl> line
12.BEGIN failed--compilation aborted at
12.[haxxanasghar at gpuserver2 ~]$ Compilation failed in require at
12.bash: Compilation: command not found...*
Please guide me in this regard.....
*Hassan Asghar*
Ph.D Computer Science
Personal Website: http://bit.ly/2OQ0egs
Google Scholar: https://bit.ly/3lVYuxF
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210610/4043e26f/attachment.html>
More information about the Darshan-users
