[Darshan-users] Problem with darshan-job-summary.pl in 3.3.0
Jeffrey Layton laytonjb at gmail.com
Mon Jun 7 12:26:32 CDT 2021
Good afternoon,
I just built version 3.3.0 and ran a simple C code that writes some text to
stdout, When I try to create a summary pdf file it hangs.
I built darhan-3.3.0 using gcc on Ubuntu 20.04. The command I used to
create the report is,
$ /home/laytonjb/bin/darshan-3.3.0/bin/darshan-job-summary.pl
laytonjb_test1_id28730_6-7-43012-2131301613401632697_1.darshan --output
jeff --verbose
verbose: /tmp/49OfEXSumv
Use of uninitialized value $summary{"POSIX_MMAPS"} in numeric lt (<) at
/home/laytonjb/bin/darshan-3.3.0/bin/darshan-job-summary.pl line 435.
Warning: empty y range [0:0], adjusting to [-1:1]
At this point it hangs. I took a peak at the directory in /tmp and found
the following:
$ ls -s
total 320
 4 access-hist-eps.gplt   4 file-access-read-sh.dat   8
file-access-write.pdf     24 op-counts.eps        8 pattern.pdf
0 summary.log             4 title.tex
 4 access-table.tex      24 file-access-shared.eps    4
file-access-write-sh.dat   4 op-counts-eps.gplt   4 posix-access-hist.dat
4 summary.tex             4 variance-table.tex
 4 file-access-eps.gplt   8 file-access-shared.pdf    4
file-count-table.tex       8 op-counts.pdf       28 posix-access-hist.eps
4 time-summary.dat
 4 file-access-read.dat   4 file-access-table.tex     4
fs-data-table.tex          4 pattern.dat          8 posix-access-hist.pdf
24 time-summary.eps
24 file-access-read.eps   4 file-access-write.dat     4
job-table.tex             24 pattern.eps          4 posix-op-counts.dat
4 time-summary-eps.gplt
 8 file-access-read.pdf  24 file-access-write.eps     4
latex.output               4 pattern-eps.gplt     4 stdio-op-counts.dat
8 time-summary.pdf
There are some pdf files and I can read those, but I was hoping for a
single pdf file that contained all of the plots like that in the
documentation for darshan-utils.
Any thoughts on what I'm doing wrong?
Thanks!
Jeff
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon>
Virus-free.
www.avast.com
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link>
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210607/04601bdb/attachment.html>
More information about the Darshan-users mailing list
