[Darshan-users] darshan-job-summary.pl question
Snyder, Shane
ssnyder at mcs.anl.gov
Wed May 20 09:41:33 CDT 2020
Great, thanks for the update, Jeff!
FWIW, we're plotting some changes to our analysis tools to base them off of Python rather than the combination of technologies our current tools are based on (including Perl and LaTeX stuff, as you see). We're hopeful that will allow these tools to be more maintainable going forward, and in this case, hopefully expressing required dependencies is greatly simplified. We'll keep the community posted as we make progress there.
In the mean time, I'll update darshan-util docs to list the package you mention as an explicit dependency.
--Shane
Sent: Wednesday, May 20, 2020 9:16 AM
To: Snyder, Shane <ssnyder at mcs.anl.gov>
Cc: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: Re: [Darshan-users] darshan-job-summary.pl question
On Wed, May 20, 2020 at 10:12 AM Jeffrey Layton <laytonjb at gmail.com<mailto:laytonjb at gmail.com>> wrote:
On Tue, May 19, 2020 at 2:48 PM Snyder, Shane <ssnyder at mcs.anl.gov<mailto:ssnyder at mcs.anl.gov>> wrote:
Not a problem at all, that's what we're here for. I'm sorry it hasn't been as straightforward of a process getting this up and running as we'd hope. FWIW, we really appreciate all of the feedback, this is all really helpful!
No worries. Anything I can do to help (BTW - I'm probably a strange bird, but I like doing documentation so if you have any needs or desired, let me know and I'll see what I can do).
Also, I'm betting I'm one of the few to use Ubuntu 18.04 :) I'm using Darshan for some work related things and I'm boxed into using Ubuntu 18.04 exclusively. I actually like it so I'm not complaining, but it is a constraint.
It looks like the system you're using doesn't have the required Perl Latex module we're using as part of darshan-job-summary. Can you try installing the following package with your package manager to see if it helps work around that:
texlive-latex-extra
We should update our documentation to clearly indicate that as another explicit dependency, if so. That was probably just an oversight on our part.
Installing this package got me further, but I'm getting an error about another missing package:
$ darshan-job-summary.pl<http://darshan-job-summary.pl> --output jeff.pdf /usr/local/darshan-logs/2020/5/19/laytonjb_ex1_id4630_5-19-28572-4707187774811817098_1589889373.darshan
Can't locate Pod/LaTeX.pm in @INC (you may need to install the Pod::LaTeX module) (@INC contains: /usr/local/lib /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/local/lib/TeX/Encode.pm line 10.
BEGIN failed--compilation aborted at /usr/local/lib/TeX/Encode.pm line 10.
Compilation failed in require at /usr/local/bin/darshan-job-summary.pl<http://darshan-job-summary.pl> line 12.
BEGIN failed--compilation aborted at /usr/local/bin/darshan-job-summary.pl<http://darshan-job-summary.pl> line 12.
I'm looking around for LaTeX.pm without much luck yet. The only thing I've found that is close is libpod-latex-perl but I'm struggling to find the corresponding package :) I'm still looking but if you find the package I would appreciate it.
Aha! I found it: libpod-latex-perl.
Thanks!
Jeff
Thanks!
Jeff
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov<mailto:darshan-users-bounces at lists.mcs.anl.gov>> on behalf of Jeffrey Layton <laytonjb at gmail.com<mailto:laytonjb at gmail.com>>
Sent: Tuesday, May 19, 2020 9:46 AM
To: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov> <darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov>>
Subject: [Darshan-users] darshan-job-summary.pl<http://darshan-job-summary.pl> question
Good morning,
I really apologize for being a pest :) I've been able to profile an extremely simple C code and I'm ready to post-process. I wanted to experiment with darshan-job-summary.pl<http://darshan-job-summary.pl>. When I run it, I get the following message:
$ darshan-job-summary.pl<http://darshan-job-summary.pl> /usr/local/darshan-logs/2020/5/19/laytonjb_ex1_id4630_5-19-28572-4707187774811817098_1589889373.darshan
I installed the dependencies for the pdf output: gnuplot, pdflatex, epstopdf (no errors during darshan-utils build and I can run these commands). Am I missing a Perl module?
Thank you very much!
Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200520/5d626ed9/attachment.html>
More information about the Darshan-users
