[Darshan-users] darshan-job-summary.pl question
Jeffrey Layton laytonjb at gmail.com
Wed May 20 10:29:22 CDT 2020
On Wed, May 20, 2020 at 2:41 PM Snyder, Shane <ssnyder at mcs.anl.gov> wrote:
> Great, thanks for the update, Jeff!
> FWIW, we're plotting some changes to our analysis tools to base them off
> of Python rather than the combination of technologies our current tools are
> based on (including Perl and LaTeX stuff, as you see). We're hopeful that
> will allow these tools to be more maintainable going forward, and in this
> case, hopefully expressing required dependencies is greatly simplified.
> We'll keep the community posted as we make progress there.
Sounds good! I'll look for the new tools.
> In the mean time, I'll update darshan-util docs to list the package you
> mention as an explicit
Thanks!
Jeff
dependency.
> --Shane
> *From:* Jeffrey Layton <laytonjb at gmail.com>
> *Sent:* Wednesday, May 20, 2020 9:16 AM
> *To:* Snyder, Shane <ssnyder at mcs.anl.gov>
> *Cc:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
> *Subject:* Re: [Darshan-users] darshan-job-summary.pl question
> On Wed, May 20, 2020 at 10:12 AM Jeffrey Layton <laytonjb at gmail.com>
> wrote:
> On Tue, May 19, 2020 at 2:48 PM Snyder, Shane <ssnyder at mcs.anl.gov> wrote:
> Not a problem at all, that's what we're here for. I'm sorry it hasn't been
> as straightforward of a process getting this up and running as we'd hope.
> FWIW, we really appreciate all of the feedback, this is all really helpful!
> No worries. Anything I can do to help (BTW - I'm probably a strange bird,
> but I like doing documentation so if you have any needs or desired, let me
> know and I'll see what I can do).
> Also, I'm betting I'm one of the few to use Ubuntu 18.04 :)  I'm using
> Darshan for some work related things and I'm boxed into using Ubuntu 18.04
> exclusively. I actually like it so I'm not complaining, but it is a
> constraint.
> It looks like the system you're using doesn't have the required Perl Latex
> module we're using as part of darshan-job-summary. Can you try installing
> the following package with your package manager to see if it helps work
> around that:
> texlive-latex-extra
> We should update our documentation to clearly indicate that as another
> explicit dependency, if so. That was probably just an oversight on our part.
> Installing this package got me further, but I'm getting an error about
> another missing package:
> $ darshan-job-summary.pl --output jeff.pdf
> /usr/local/darshan-logs/2020/5/19/laytonjb_ex1_id4630_5-19-28572-4707187774811817098_1589889373.darshan
> Can't locate Pod/LaTeX.pm in @INC (you may need to install the Pod::LaTeX
> module) (@INC contains: /usr/local/lib /etc/perl
> /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1
> /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5
> /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26
> /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at
> /usr/local/lib/TeX/Encode.pm line 10.
> BEGIN failed--compilation aborted at /usr/local/lib/TeX/Encode.pm line 10.
> Compilation failed in require at /usr/local/bin/darshan-job-summary.pl
> line 12.
> BEGIN failed--compilation aborted at /usr/local/bin/darshan-job-summary.pl
> line 12.
> I'm looking around for LaTeX.pm without much luck yet. The only thing I've
> found that is close is libpod-latex-perl but I'm struggling to find the
> corresponding package :)  I'm still looking but if you find the package I
> would appreciate it.
> Aha! I found it: libpod-latex-perl.
> Thanks!
> Jeff
> Thanks!
> Jeff
> --Shane
> *From:* Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf
> of Jeffrey Layton <laytonjb at gmail.com>
> *Sent:* Tuesday, May 19, 2020 9:46 AM
> *To:* darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
> *Subject:* [Darshan-users] darshan-job-summary.pl question
> Good morning,
> I really apologize for being a pest :)  I've been able to profile an
> extremely simple C code and I'm ready to post-process. I wanted to
> experiment with darshan-job-summary.pl. When I run it, I get the
> following message:
> line 12.
> line 12.
> I installed the dependencies for the pdf output: gnuplot, pdflatex,
> epstopdf (no errors during darshan-utils build and I can run these
> commands). Am I missing a Perl module?
> Thank you very much!
> Jeff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20200520/6a38744a/attachment-0001.html>
More information about the Darshan-users mailing list
